I’m having trouble with my GL-X750V2 that’s been working great for the past 3 months on the T-Mobile network. All of a sudden this Saturday, I lost network access and I have a message that says, “SIM card cannot be registered. Please check: 1. You are using the compatible modem for your carrier; 2. Whether a specific APN or data plan is required.” The SIM card is still functional in my smartphone; I tried a different SIM card and different APN settings with no success. I don’t know if anybody else has had this issue. The SIM card has a basic unlimited data plan for talk, text, and data with a 5 GB hotspot.
Any help and advice would be greatly appreciated.
Have you upgraded to firmware 3.215?
Yes, it is running the latest firmware 3.215. That was one of the first things I did when I couldn’t get anything else to work
Thank you though
Hi, could you solve the problem?. I have the same device, it worked correctly, but now I get this error, “SIM card cannot be registered. Please check: 1. You are using the compatible modem for your carrier; 2. Whether a specific APN or data plan is required”
I appreciate any idea, tip to correct it,
Can you send us an email with more details, e.g. modem model and carrier.
support at glinet.biz
