New to the router, but I am trying to use the REST API to get information from the X750V2 Router, and although I can get my token using CURL, I can’t get anything other than Error 0: from the Router.
I have changed the IP address in the REST API page and added my token aabbccdd112233eeffgg in the box, even tried it with quotes, but it doesn’t make any difference.
What am I missing? Is there anything I need to enable?
Firmware: V3.203
TIA
EDIT:
Managed to get a CURL command to work…
curl -H “Authorization: aabbccdd1122334455eeff” --cookie “QSESSIONID=9177564b1203c30000” 192.168.3.1/api/ap/detect
Are you saying that the REST API page with the boxes for input does not work?
I was trying to use the API page to fetch the results of the API calls that interested me. This would save me writing the commands manually each time during testing.
I can get the API to work using Curl, but not all API calls seem to return a result.
If there is a redesign, when can we expect to see API v4.0 to be released? In the meantime v3.01 is all we seem to be able to work with…
Is this value persistent until the next token request, even through switching off and on??
What circumstances cause the token to change?
Sorry for the questions, just trying to get my head around your implementation of the REST API.
