Winscp should use SCP, not SFTP protocol.
"sms_support" seems to be configured on "false".
By side of that : now that I have an upgraded modem wouldn't it be easier to restore the whole device to the latest version ?
4.3.17 is the latest firmware of the xe300
Looks like there's still a problem with the code that needs to be fixed
Can I debug it remotely?
Technical Support via GoodCloud.tar (192 KB)
Do I have to tweak some flat configuration file settings somewhere ? ![]()
Even restoring the whole firmware from scratch wouldn't help at that stage ?
You can try to restore factory Settings
If that doesn't work, please share your device
hello
Any problems restoring factory Settings?
I don't have much time to try that these days.
Anyway, in the meantime, if you have any other idea, I'm open to suggestions ![]()
You can share your device with goodcloud
I'll debug the problem remotely
Ensure that an Internet access mode other than the modem is available
It won't take long
thank you
Did this end up being resolved? I am having the same issue, can receive SMS but cannot reply/send.
There appears to be no option to send.
Firmware version below. v4.3.18 (Date 2024-08-23)
Router model?
Model model?
Consider upgrading the modem firmware
XE300C6 (Puli)
Modem EP06ELAR03A08M4G
Am stuck on the second last line "Cannot open output file: File exists"
The first time I did this, a system error dialogue box popped up just as I was trying to upgrade Quectel module software.
Edit: Sorry I am new here. If this firmware upgrade discussion is more appropriate in another forum/environment, then please let me know
The file already exists, therefor you can't save it (again)
Run rm QFirehose-* before to clean up.
Thanks all. Took a bit of time but I upgraded modem firmware to EP06ELAR04A22M4G. Unfortunately the SMS screen is still the same. It's Ok though, while a handy function, I can learn to live without it.
hello
Can you try sending with the AT command?
Of course, if you think it's too much trouble
You can share your device with me and I will test it remotely
thank you
opkg update
opkg install minicom
minicom -D /dev/ttyUSB2
Enable local echo to view entered commands:
CTRL+A then press E
AT+CMGF=1 and press Enter
AT+CMGS= "+phonenumber" and press Enter
> Write your message (it won't appear on minicom) and press CTRL+Z
+CMGS: 8
OK
quit
CTRL+A then press Q then Enter
Can you help me with that issue?
It's a GL-XE300, Current Firmware Version 4.0 Firmware Type 0323beta2, EP06ELAR04A22M4G and it's shared in GoodCloud with gl.inet_support. The device id is sy482b6.
Since the version 4.0 the feature to send SMS is disabled. I even upgraded to the latest to manage the eSIM, it's working perfectly but the SMS still no.
Just to mark here, problem solved and fix will be in firmware 4.5 and later.
Hello @alzhao ,
Seems like there is a 4.7 version ahead but right now, our PULIs are limited to a 4.0 beta.
This device will only receive a 4.5 but not a 4.7 if I understand correctly ?
Thanks
