I wanted to know if tailscale is present in the new 4.3.6 version. I wanted to know if it is possible to install and manage it from the graphical interface.
Also I wanted to know if it is possible to install it also in version 3.217
Sorry, XE300 does not have enough hardware resources to run Tailscale.
I installed the beta version with firmware 4.3
Later I installed these packages. Activating tailscale was a bit tricky because I had to get the activation link from the LOGs. Otherwise it just generates an error in the logs that you should fix yourself.
I have sent the logs to you via email
I did install the packages mentioned above and also followed this guide to setup the firewall:
https://openwrt.org/docs/guide-user/services/vpn/tailscale/start
It seems to work but when i ping via tailscale i do get alot of timeouts and connection is unstable. Did someone get tailscale to work properly on the device ?
im speacially interested in subnet routes. I want to be able to connect to all devices connected to wifi/lan to the xe300 via tailscale.
