Thanks everyone for your help.
The next step would be to check on which LTE / 4G band(s) do your phone and tablet use to connect to the mobile carrier (there should be in the Apps Store, few apps that have been downloaded more than 1 Million times for this)
After you find the bands used by your phone/ tablet - you compare it with your Puli router
Here is a website on how does T-Mobile Poland uses its bands (I donât know if the information is up to date)
Your iPhone/iPad most likely has a much higher cat rated modem, which means that data is delivered over more band frequencies at the same time, which results in higher speeds.
In real world usage your puli with a cat 6 modem (2x2 Mimo cellular) can score about 100-150 Mbps max. Depending on your mobile network cell, the actual numbers of users using data in your cell, the used frequencies and distance to the networks cellular antennas (and obstacles in the way), everything from 20-50 Mbps with a cat 6 modem is good.
If you want to have higher speeds with the modem, you need to invest in a better modem/router. Gl.inet has only two routers atm which support faster speeds (spitz AX - X3000 without a battery and puli AX - XE3000 with built in battery). Both routers will no significantly bigger and heavier than your puli router, but will deliver faster speeds.
That TMobile PL description is outdated. They switched off 3G recently and now have LTE 900@5 MHz (Band 8).
Thanks for the replies.
However, one thing puzzles me. So there is currently no router to which we will insert a sim card and the internet will work as fast as in an iPad or iPhone?
I bought another 4G-N16 router today and the same thing is happeningâŚ
@silkweb
Yes, this router.
Now I donât know if each router will have max. 20Mbps or whatever. I have unlimited data and speed with T-mobile.
Your Puli XE300, I assume that it had inside a Quectel EP06-E modem, which means a LTE Cat 6
You bought another router (letâs say a No Name modem router) with a LTE Cat 4 modem
by comparison
iPhone XS, iPhone SE (2020) is Cat 16
iPhone X and iPhone XR, both pack Cat 12 LTE modems
iPhone 11 Pro is Cat 19
My question is: why do you think that you can do a downgrade (yes, downgrade) from a cat 6 router to a cat 4 router and obtain the same performance as a device with a Cat 16 modem?
@silkweb
We are looking for a hole in the whole. Letâs go back to the beginning of my first question, because we have developed the thread so much that we completely change the subject.
The router I ordered and tried different settings doesnât even work at 30mbps.
I wanted to buy another one and see if there is any dependency - as I have experienced now - there is none. It still doesnât even exceed 20mbps.
So my question is: Are there currently no routers on the market that, after inserting a sim card, will operate at a speed of, for example, about 100 mb/s?
If so, which ones? Currently I am thinking about buying: ZTE_MC801A and testing it.
OR this router Huawei B818-263.
Unless there is a proven router with GL-iNET that will allow higher speeds.
If you want a router close to IPhone or Ipad speeds then I would recommend you to try
GL.iNet Spitz AX 5G - X3000 or
GL.iNet Puli AX 5G - XE3000
@silkweb
Thanks for the recommendation. I see that these devices are currently not available to everyone in the store.
