I have two video surveillance systems. I connected the two video surveillance systems between the wan networks. I would like to give internet priority to the 4G line, rather than the wan network. I would also like to be able to access the two video surveillance systems remotely.
I can not with XE-300 to do this.
This is my scenario:
I’ve seen that firmware 4.2 (beta) does prioritize but 4g doesn’t work. The system is not stable and gives errors.
I ask you, with firmware 3, if I can do it with mwan3 and how to set it. Thank you
The different interfaces (luci (/advanced settings) → network → interfaces) have a gateway weight. This gateway weight defines the priority of that interface. If you reverse those weights, mwan will reverse the priority.
I did this but I noticed that in the configuration the weight in the gateway for the modem (4G/LTE) is not configurable from the interface. (see photo)
However I want priority on the 4G network, so that if the “4G/LTE” network goes down, it uses the WAN, but as soon as it starts working again, it immediately returns to the 4G network.
I changed the member metrics on mwan3. Now everything seems to work. I hope I did right.
Too bad the same interface was not made on the gl-inet panel for firmware version 3.
