Thanks. Problem is solved with the new firmware
Thanks
Stefan
with the newest firmware (12/27/2024). running X3000 as WDS client, MT6000 as WDS server. wifi client now shows up in X3000's client list. however, none of X3000's client shows up in MT6000's client list. in previous (4.7.0) firmware, X3000's clients show up in MT6000's client list.
No matter what slot; sms does not work for me. ESIM is in Slot 1 and Vodafone sim in Slot 2. when I Switch no change.
New firmware with Same Release Level is offered in Upgrade section…..
I think there is no GSM Data Used reset feature available on GL-XE3000 Puli AX 4.7.1 2024-12-27
Even not by clicking on the current data usage counter?
I just checked @admon, it doesn't have that option.
Please upgrade the latest beta firmware.
If the issue still occurs, please share your router with me via GoodCloud.
This request is in the development plan.
If be clear statistics, you can uncheck 'sava data when power off' and reboot the router.
I think there is another bug with the GL-XE3000 Puli AX (version 4.7.1, 2024-12-27). My router is plugged into the power, and the battery was at 100%. Suddenly, the battery level dropped to 98%, and the battery LED started blinking. It never reaches 100% again unless I unplug the power and plug it back in. If I try to restart the router without unplugging it, it doesn’t fix the issue. any idea ?
