GL-XE3000 How to read battery / charge status?
I'm running several GL-XE3000 routers and I would like to be able to read if the battery is charging or not, as I want to create a script that sends an email if the power adapter is disconnected, so I can be aware if there has been a power outage or if someone disconnected the router from power.
How can I read the charge status using a cmdline? I've searched the forum but I haven't found any specific information for this router.
Thank you.
ubus call mcu status
Thank you, it worked flawlessly.
For anyone wondering, this doesn't work out of the box on the xe300 openwrt build, you need the gl-puli-mcu package
