at this moment with xe3000-4.0-0408release3 gl.inet firmware
which Quectel_RM520N-GL-AA_A_ modem firmware is encouraged or discouraged ?
RM520NGLAAR03A03M4G_01.201.01.201
2024-03-28
or
RM520NGLAAR03A02M4GA_2023_11_06
2023-11-06
or
https://fw.gl-inet.com/tools/quectel_module_software
RM520NGLAAR01A07M4G_01.201.01.201
(I believe) 2023-06-28
also
as per Upgrade Quectel Module Software - GL.iNet Router Docs 4 documentation
is QFirehose-mtk7981a-sha256-c0b944 still best choice or is
opkg install qfirehose
a better choice?
Thanks for great support!
This one and I have been running it for few weeks without any issues .
thanks so much for letting us know!
which qfirehose did you install with?
I used this one:
https://fw.gl-inet.com/tools/quectel_tool/QFirehose-mtk7981a-sha256-c0b944
All steps are listed here:
Just to not make any mistake : … my RM520NGLAAR03A03M4G_01.201.01.201.zip has md5sum 6deb45893ce2088729708c9790e4d742 and comes from
… I suppose yours has same md5sum ?
ywp
6
Just use this. No problem
