I have a Puli AX which works perfectly (v4.4.8 2024-04-19). The only issue I use Papertrail to aggregate syslogs from the routers. When it’s configured to an external syslog router, it spams to Papertrail, no matter what the “Log output level” is set to, from “debug” to “Emergency” — Here is a snippet of what it’s spitting out over and over again:
May 05 19:20:19 GL-XE3000 kernel [759742.125672] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(1),SYNC(2),AUTH(0),ASSOC(0)
May 05 19:20:20 GL-XE3000 kernel [759743.695336] 7981@C09L2,sync_fsm_join_timeout_action() 1091: ProbeTimeoutAtJoinAction
May 05 19:20:21 GL-XE3000 kernel [759744.215643] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x190/0x348 [mt_wifi]
May 05 19:20:21 GL-XE3000 kernel [759744.225067] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(1),SYNC(2),AUTH(0),ASSOC(0)
May 05 19:20:22 GL-XE3000 kernel [759745.710747] 7981@C09L2,sync_fsm_join_timeout_action() 1091: ProbeTimeoutAtJoinAction
May 05 19:20:23 GL-XE3000 kernel [759746.323043] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x190/0x348 [mt_wifi]
May 05 19:20:25 GL-XE3000 kernel [759748.334138] 7981@C09L2,sync_fsm_join_timeout_action() 1091: ProbeTimeoutAtJoinAction
May 05 19:20:25 GL-XE3000 kernel [759748.410518] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x190/0x348 [mt_wifi]
May 05 19:20:25 GL-XE3000 kernel [759748.419937] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(1),SYNC(2),AUTH(0),ASSOC(0)
May 05 19:20:27 GL-XE3000 kernel [759750.349566] 7981@C09L2,sync_fsm_join_timeout_action() 1091: ProbeTimeoutAtJoinAction
May 05 19:20:27 GL-XE3000 kernel [759750.509972] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x190/0x348 [mt_wifi]
May 05 19:20:27 GL-XE3000 kernel [759750.519390] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(1),SYNC(2),AUTH(0),ASSOC(0)
Other than that, the Puli AX works perfectly. I don’t even know what it’s complaining about and this is the only GL.iNet router which is spitting it out. Any idea what’s going on? Thanks in advance.
