GL-XE3000 Snapshot firmware
Hello
I’ve noticed that the snapshot firmware for the GL-XE3000 (Pulli)
still has nightly builds. However the last update seems to be the fix for rtty on the 26th March.
Are there still nightly bugs being fixed (since the rtty fix)?
Perhaps the webpage is just “full” can’t display updates since the 26th?
I don’t need fixes for the issues mentioned on the change log but I like to keep my router upto date.
Angela.
p.s the router has been rock solid :slight_smile:
Currently, the v4.8 firmware has reached a relatively stable state, so new fixes may not be merged into the snapshot daily. However, since snapshot firmware is built automatically every day through CI/CD—not triggered by new fixes—it will still be released daily.
