Hi Everyone !
I need some support, here, had this Model of router(GL-XE3000NR),
I dont know why is like connecting in Tethering mode ( the quectel modem), any suggestion or steps to try to solve this I will going to appreciate .
Hi Everyone !
My first steps would be:
AT+QPRTPARA=3Which firmware do you use currently?
The modem is RNDIS mode, it dial-up itself, and DHCP the IP (NAT) for the connected device (such as the GL router)
How to exit the RNDIS mode? Guess you enable it using some AT commands?
Thank you all for the response; sorry for the late replay! I would like to revert exist any way ?, I cant use the device
