GLAR300M16 Tor Support
Hello Guys
I have GL-AR300M16 Router with current firmware 3.2.11 under vpn option I do not find any Tor options. does this mini router support TOR ?
Because Tor is big. So for some models that only have 16M flash, it is removed from the firmware.
You can go to applications->plugins, first refresh the repo then install gl-tor.
If you have no space, you may need to use USB memory key and use exroot.
My gl-ar300m16 isn't even recognising my usb so I can add plug ins. It's not even registering that I have a usb in there. What can I do
Appreciate that if you don't reply on a 3-year old post and include details e.g. log of your issue.
