Glddns offline
Hi, is the glddns service offline? My dns isnt receiving any response.
Wireguard message: one or more endpoint domains could not be found.
Glinet router log: name is not resolved iqadxxx.glddns.com
Any news about this issue? It was working fine yesterday. I was able to create a vpn with my homeadress.
Thanks in advance.
Can you still connect to your router using GoodCloud?
I am not familiar with goodcloud. What is this? Can you provide me with some more information?
Fyi. I am far away from home so I cannot do any configuration at that side.
Well, in that case you can't do anything, I guess.
DDNS isn't down right now so your home router seem to have issues. Without the possibility to check that … no way to get it work again.
Alright. Thanks. I am wait a bit and see if there is maybe a internet problem at my home adress.
Thanks for now!!
Please read GoodCloud - GL.iNet Router Docs 4 so you might have the access even if GLDDNS has issues.
Seem so, yes.
For further troubleshooting, the logs of the router (the server one) are needed.
Hi, were you able to fix it? How did you resolve the problem?
Rebinding DDNS should do the job. So restarting the DDNS process.
Fixed by using my wan ip. I will reset the ddns proces once I am home.
Hi Admon, it looks like according to your outage tracker the DDNS service was out for 4 days?
https://glinet-status.admon.in.ua/
Now its showing no outage but many of my devices are still unable to resolve the DDNS. Has it been fully fixed or what do i need to do to fix?
My devices show this error when doing DDNS Test "The DNS Record for this DDNS domain could not be found by the DNS server. Please check the internet connection of this device." Doing a manual nslookup also shows non existent domain
This was an issue with my inofficial monitoring because the DNS servers stopped responding to TCP. Now I implemented UDP check for DNS which works better.
I don't know if there was an real issue (or maybe there is an ongoing one)
I see. Any idea on next steps to troubleshoot this issue?
In order not to disclose your ddns I suggest that you send via email to support at glinet.biz
With your ddns and screenshot of your test.
Is glddns.com down ?
No wireguard session possible
Error message:
DNS name could not resoveld
Please check if your GLDDNS hostname still resolves by using this: https://dnschecker.org/
Will it return results?
No returns
From Germany also from Türkiye
I sent you a PM to check this so you don't need to post your DDNS here :slight_smile:
