Router model: GL-MT6000 (Flint 2)
Firmware version: v4.5.8
Device ID: bf2d825
MAC: 94:83:C4:A2:D8:25
S/N: 8d298d16c02607ef
Hi, I’m having a DDNS registration issue that I’ve diagnosed down to the update endpoint itself rejecting my hostname. Hoping someone from the team can take a look at this specific Device ID.
Symptom:
DDNS has been failing continuously for several hours with “IP update not accepted by DDNS Provider” in the log, retrying every 10 minutes with no success.
Diagnosis so far:
nslookup bf2d825.glddns.comresolves to0.0.0.0(not my actual public IP)- Manually hitting the standard update endpoint:
curl -v "http://[USERNAME]:[PASSWORD]@ddns.glddns.com/nic/update?hostname=bf2d825&myip=[MY_PUBLIC_IP]"
Returns: HTTP/1.1 404 Not Found (nginx/1.17.7)
- Also tried the alternate TLS endpoint (found in another thread on this forum as a past fix for a similar issue):
curl -vk "https://[USERNAME]:[PASSWORD]@ddns-tls.glddns.com/nic/tls/update?hostname=bf2d825&myip=[MY_PUBLIC_IP]"
Also returns: HTTP/1.1 404 Not Found (same nginx server)
- For comparison, GoodCloud works fine with this same Device ID — I can see successful
connected: trueentries in the Cloud Log using the same MAC/SN/Device ID, so this looks isolated to the DDNS registration specifically, not a general account/device issue. - I’ve toggled DDNS off/on multiple times (including full restarts of the updater via SSH) over about 2 hours, with no change — still consistent 404s on every attempt.
Timing note: this started around the same time I was setting up/binding this device to GoodCloud (enabling remote access, adding it via Device ID in the GoodCloud dashboard). Not sure if related, but flagging in case the two processes share backend provisioning.
Question: Is this something that can be fixed server-side for this Device ID (re-provisioning the DDNS hostname registration), or would removing and re-adding the device from GoodCloud resolve it? I didn’t want to do that without checking first, in case it disrupts the working GoodCloud connection or complicates diagnosing the root cause.
Happy to provide any additional logs or run further diagnostics. Thanks in advance.
