GLinet 750S & 750M Wireguard no LAN
I have here a GLinet 750S and wanne use it as a Wireguard server to a othe GLinet router (model 750M).
The connection with wireguard between the server (750S) and the client (750M) is good.
Only i wanne browse on the other network. How can i enable that?
So far i got a green dot between te server and client. I wanne browse over the other LAN. And the other LAN want to browse over my LAN.
I did read i must add IP addresses by allowed IP. That option accept’s only one IP (between the connection IP).
When i do , and save and look back in the file config i see both IP adresses. When i wanne connect i got a connection with a Yellow dot. I can’t reach then the other side.
That dit the trick.
First i had a problem with the login on the router with SSH. (Don't accept the password).
After a complete reset (software button in the webinterface) no login on SSH. I can connect but no login (password not ok).
After reset with button the same as above.
After a firmware update i finally have a good login.
Visit Client’s LAN Subnet
Visit Client’s LAN Subnet from WireGuard Server LAN Subnet
  1. Change WireGuard clients LAN IP to avoid IP confliction with Server
  2. Modify Wireguard_Server Configuration
WinSCP or SSH into your the WireGuard Server (router) find and modify the file
/etc/config/wireguard_server
Add a line to the end of the config file of clients you want to visit.
list subnet '192.168.xxx.0/24'
Save and Exit
Have you solved problems about wireguard?
Yes, see above in my post.
