GLiNet iOS app cannot switch between two connected devices
I have the GL-X3000 and GL-MT6000 properly registered (logged in) with the GLiNet iOS app, currently browsing the GL-MT6000, then when I go to the menu and try to connect to the GL-X3000, it will ask me for the GL-MT6000 password.
The switching between devices is not working for me, or I am doing something wrong, print screens below, please any advise will be appreciated, thank you
Any feedback from the GL.iNet team? Thank you
You may have changed the administrator password of GL-X3000 somewhere else, you can forget the GL-X3000 first, and then re-add the GL-X3000 management. App There is a bug here, the APP is supposed to re-enter the admin password of GL-X3000. This bug will be fixed in subsequent versions, thank you very much.
Thank you, the password for the GL-X3000 is correct, the problem is:
When I try to switch from the current router, GL-MT6000 to the GL-X3000, I get a pop up screen asking for the password for the GL-MT6000, instead of switching to the GL-X3000.
There is no way to switch to the GL-X3000, I have to go Add New Devices, then Initialized Devices enter the IP of the GL-AX3000 and it will connect to the GL-X3000 after entering the password, but then I cannot switch back to the GL-MT6000.
It seems there is a bug in the app.
The
Sorry, there is a bug, we will fix it in the next version. For the time being, you can set the administrator password of both routers to be the same via web, and then the app re-added the router, the app can switch the router correctly.
