I believe the issue has been resolved by turning off the auto scan and reconnect feature.
Since i turned it off, it has remained connected.
The firmware is most recent version.
I will post here again if I am disconnected, but I suggest you guys take a look at the code for the auto scan and reconnect feature.
Thanks for replying.
Great service as usual.
Okay it seems that wasn’t the issue… It just happened again as I posted my last reply.
I can only post the last several lines in the log, as the character limit here is 3000.
Wed Aug 7 01:49:31 2019 daemon.info dnsmasq-dhcp[2443]: read /etc/ethers - 0 addresses
Wed Aug 7 01:49:37 2019 kern.info kernel: [25973.978195] IPv6: ADDRCONF(NETDEV_UP): tmp.radio1: link is not ready
Wed Aug 7 01:49:38 2019 user.info : [ 2069] gl-wifi-core>> bIsStaEnabled=1
Wed Aug 7 01:49:40 2019 kern.info kernel: [25976.821533] IPv6: ADDRCONF(NETDEV_UP): wlan-sta: link is not ready
Wed Aug 7 01:49:40 2019 daemon.notice netifd: radio1 (23257): Successfully initialized wpa_supplicant
Wed Aug 7 01:49:40 2019 daemon.notice netifd: Interface 'wwan' is enabled
Wed Aug 7 01:49:41 2019 kern.info kernel: [25978.311592] wlan-sta: authenticate with 18:90:d8:ca:b8:4e
Wed Aug 7 01:49:41 2019 kern.info kernel: [25978.329740] wlan-sta: send auth to 18:90:d8:ca:b8:4e (try 1/3)
Wed Aug 7 01:49:41 2019 kern.info kernel: [25978.338490] wlan-sta: authenticated
Wed Aug 7 01:49:41 2019 kern.info kernel: [25978.350159] wlan-sta: associate with 18:90:d8:ca:b8:4e (try 1/3)
Wed Aug 7 01:49:41 2019 daemon.notice netifd: Network device 'wlan-sta' link is up
Wed Aug 7 01:49:41 2019 daemon.notice netifd: Interface 'wwan' has link connectivity
Wed Aug 7 01:49:41 2019 daemon.notice netifd: Interface 'wwan' is setting up now
Wed Aug 7 01:49:41 2019 kern.info kernel: [25978.363918] wlan-sta: RX AssocResp from 18:90:d8:ca:b8:4e (capab=0x411 status=0 aid=1)
Wed Aug 7 01:49:41 2019 kern.info kernel: [25978.372433] wlan-sta: associated
Wed Aug 7 01:49:41 2019 daemon.notice netifd: wwan (23372): udhcpc: started, v1.28.3
Wed Aug 7 01:49:41 2019 daemon.notice netifd: wwan (23372): udhcpc: sending discover
Wed Aug 7 01:49:42 2019 kern.info kernel: [25979.365156] IPv6: ADDRCONF(NETDEV_CHANGE): wlan-sta: link becomes ready
Wed Aug 7 01:49:44 2019 daemon.notice netifd: wwan (23372): udhcpc: sending discover
Wed Aug 7 01:49:45 2019 daemon.warn odhcpd[1871]: DHCPV6 CONFIRM IA_NA from 0001000123d159ba9828a636769f on br-lan: not on-link fdc9:8869:17c8:10::d55/128
Wed Aug 7 01:49:45 2019 daemon.warn odhcpd[1871]: DHCPV6 SOLICIT IA_NA from 0001000123d159ba9828a636769f on br-lan: ok fdc9:8869:17c8:10::d55/128
Wed Aug 7 01:49:45 2019 daemon.info dnsmasq[2443]: read /etc/hosts - 4 addresses
Wed Aug 7 01:49:45 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/odhcpd - 0 addresses
Wed Aug 7 01:49:45 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Wed Aug 7 01:49:45 2019 daemon.info dnsmasq-dhcp[2443]: read /etc/ethers - 0 addresses
Wed Aug 7 01:49:46 2019 daemon.warn odhcpd[1871]: DHCPV6 REQUEST IA_NA from 0001000123d159ba9828a636769f on br-lan: ok fdc9:8869:17c8:10::d55/128
Wed Aug 7 01:49:46 2019 daemon.info dnsmasq[2443]: read /etc/hosts - 4 addresses
Wed Aug 7 01:49:46 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/odhcpd - 1 addresses
Wed Aug 7 01:49:46 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Wed Aug 7 01:49:46 2019 daemon.info dnsmasq-dhcp[2443]: read /etc/ethers - 0 addresses
Wed Aug 7 01:49:47 2019 daemon.notice netifd: wwan (23372): udhcpc: sending discover
Wed Aug 7 01:50:41 2019 daemon.notice netifd: wwan (23372): udhcpc: sending select for 192.168.2.35
Wed Aug 7 01:50:44 2019 daemon.notice netifd: wwan (23372): udhcpc: sending select for 192.168.2.35
Wed Aug 7 01:50:44 2019 daemon.notice netifd: wwan (23372): udhcpc: lease of 192.168.2.35 obtained, lease time 259200
Wed Aug 7 01:50:44 2019 daemon.notice netifd: Interface 'wwan' is now up
Wed Aug 7 01:50:44 2019 daemon.info dnsmasq[2443]: reading /tmp/resolv.conf.auto
Wed Aug 7 01:50:44 2019 daemon.info dnsmasq[2443]: using local addresses only for domain test
Wed Aug 7 01:50:44 2019 daemon.info dnsmasq[2443]: using local addresses only for domain onion
Wed Aug 7 01:50:44 2019 daemon.info dnsmasq[2443]: using local addresses only for domain localhost
Wed Aug 7 01:50:44 2019 daemon.info dnsmasq[2443]: using local addresses only for domain invalid
Wed Aug 7 01:50:44 2019 daemon.info dnsmasq[2443]: using local addresses only for domain bind
Wed Aug 7 01:50:44 2019 daemon.info dnsmasq[2443]: using local addresses only for domain lan
Wed Aug 7 01:50:44 2019 daemon.info dnsmasq[2443]: using nameserver 192.168.2.1#53
Wed Aug 7 01:50:44 2019 daemon.info dnsmasq[2443]: using nameserver 207.164.234.193#53
Wed Aug 7 01:50:45 2019 daemon.notice netifd: Network device 'wlan-sta' link is down
Wed Aug 7 01:50:45 2019 daemon.notice netifd: Interface 'wwan' has link connectivity loss
Wed Aug 7 01:50:45 2019 kern.info kernel: [26042.292907] wlan-sta: deauthenticating from 18:90:d8:ca:b8:4e by local choice (Reason: 3=DEAUTH_LEAVING)
Wed Aug 7 01:50:45 2019 daemon.notice netifd: wwan (23372): udhcpc: received SIGTERM
Wed Aug 7 01:50:46 2019 daemon.warn odhcpd[1871]: DHCPV6 CONFIRM IA_NA from 0001000123d159ba9828a636769f on br-lan: not on-link fdc9:8869:17c8:10::d55/128
Wed Aug 7 01:50:46 2019 daemon.warn odhcpd[1871]: DHCPV6 SOLICIT IA_NA from 0001000123d159ba9828a636769f on br-lan: ok fdc9:8869:17c8:10::d55/128
Wed Aug 7 01:50:46 2019 daemon.info dnsmasq[2443]: read /etc/hosts - 4 addresses
Wed Aug 7 01:50:46 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/odhcpd - 0 addresses
Wed Aug 7 01:50:46 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Wed Aug 7 01:50:46 2019 daemon.info dnsmasq-dhcp[2443]: read /etc/ethers - 0 addresses
Wed Aug 7 01:50:47 2019 daemon.warn odhcpd[1871]: DHCPV6 REQUEST IA_NA from 0001000123d159ba9828a636769f on br-lan: ok fdc9:8869:17c8:10::d55/128
Wed Aug 7 01:50:48 2019 daemon.info dnsmasq[2443]: read /etc/hosts - 4 addresses
Wed Aug 7 01:50:48 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/odhcpd - 1 addresses
Wed Aug 7 01:50:48 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Wed Aug 7 01:50:48 2019 daemon.info dnsmasq-dhcp[2443]: read /etc/ethers - 0 addresses
Wed Aug 7 01:50:48 2019 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Wed Aug 7 01:50:50 2019 daemon.warn dnsmasq[2443]: no servers found in /tmp/resolv.conf.auto, will retry
Wed Aug 7 01:50:50 2019 daemon.notice netifd: Interface 'wwan' is disabled
Wed Aug 7 01:51:02 2019 kern.info kernel: [26059.428040] IPv6: ADDRCONF(NETDEV_UP): tmp.radio1: link is not ready
Wed Aug 7 01:51:05 2019 user.info : [ 2069] gl-wifi-core>> bIsStaEnabled=1
Wed Aug 7 01:51:06 2019 daemon.notice hostapd: wlan0: interface state ENABLED->DISABLED
Wed Aug 7 01:51:06 2019 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED d4:e6:b7:2c:11:d7
Wed Aug 7 01:51:06 2019 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED 50:76:af:dd:a4:dc
Wed Aug 7 01:51:06 2019 daemon.notice hostapd: wlan0: AP-DISABLED
Wed Aug 7 01:51:06 2019 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Wed Aug 7 01:51:06 2019 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Wed Aug 7 01:51:06 2019 kern.info kernel: [26062.797160] device wlan0 left promiscuous mode
Wed Aug 7 01:51:06 2019 kern.info kernel: [26062.801924] br-lan: port 2(wlan0) entered disabled state
Wed Aug 7 01:51:06 2019 daemon.notice netifd: Network device 'wlan0' link is down
Wed Aug 7 01:51:07 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Wed Aug 7 01:51:08 2019 kern.info kernel: [26065.217807] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Wed Aug 7 01:51:08 2019 kern.info kernel: [26065.241469] br-lan: port 2(wlan0) entered blocking state
Wed Aug 7 01:51:08 2019 kern.info kernel: [26065.246965] br-lan: port 2(wlan0) entered disabled state
Wed Aug 7 01:51:08 2019 kern.info kernel: [26065.252832] device wlan0 entered promiscuous mode
Wed Aug 7 01:51:08 2019 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->HT_SCAN
Wed Aug 7 01:51:08 2019 daemon.err hostapd: Using interface wlan0 with hwaddr e6:95:6e:4f:a2:2c and ssid "GL-AR750S-22b-5G"
Wed Aug 7 01:51:09 2019 daemon.notice hostapd: wlan0: interface state HT_SCAN->ENABLED
Wed Aug 7 01:51:09 2019 daemon.notice hostapd: wlan0: AP-ENABLED
Wed Aug 7 01:51:09 2019 kern.info kernel: [26065.975822] IPv6: ADDRCONF(NETDEV_UP): wlan-sta: link is not ready
Wed Aug 7 01:51:09 2019 daemon.notice netifd: radio0 (25114): Successfully initialized wpa_supplicant
Wed Aug 7 01:51:09 2019 daemon.notice netifd: Interface 'wwan' is enabled
Wed Aug 7 01:51:10 2019 kern.info kernel: [26067.725965] wlan-sta: authenticate with 06:90:d8:ca:b8:4d
Wed Aug 7 01:51:10 2019 kern.info kernel: [26067.736404] wlan-sta: send auth to 06:90:d8:ca:b8:4d (try 1/3)
Wed Aug 7 01:51:10 2019 kern.info kernel: [26067.743659] wlan-sta: authenticated
Wed Aug 7 01:51:11 2019 kern.info kernel: [26067.750058] wlan-sta: associate with 06:90:d8:ca:b8:4d (try 1/3)
Wed Aug 7 01:51:11 2019 kern.info kernel: [26067.759142] wlan-sta: RX AssocResp from 06:90:d8:ca:b8:4d (capab=0x511 status=0 aid=39)
Wed Aug 7 01:51:11 2019 kern.info kernel: [26067.768744] wlan-sta: associated
Wed Aug 7 01:51:11 2019 daemon.notice netifd: Network device 'wlan-sta' link is up
Wed Aug 7 01:51:11 2019 daemon.notice netifd: Interface 'wwan' has link connectivity
Wed Aug 7 01:51:11 2019 daemon.notice netifd: Interface 'wwan' is setting up now
Wed Aug 7 01:51:11 2019 kern.info kernel: [26067.853976] IPv6: ADDRCONF(NETDEV_CHANGE): wlan-sta: link becomes ready
Wed Aug 7 01:51:11 2019 kern.debug kernel: [26067.865942] wlan-sta: Limiting TX power to 30 (30 - 0) dBm as advertised by 06:90:d8:ca:b8:4d
Wed Aug 7 01:51:11 2019 daemon.notice netifd: wwan (25296): udhcpc: started, v1.28.3
Wed Aug 7 01:51:11 2019 daemon.notice netifd: wwan (25296): udhcpc: sending discover
Wed Aug 7 01:51:11 2019 kern.info kernel: [26068.281382] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Wed Aug 7 01:51:11 2019 kern.info kernel: [26068.288138] br-lan: port 2(wlan0) entered blocking state
Wed Aug 7 01:51:11 2019 kern.info kernel: [26068.293701] br-lan: port 2(wlan0) entered forwarding state
Wed Aug 7 01:51:11 2019 daemon.notice netifd: Network device 'wlan0' link is up
Wed Aug 7 01:51:11 2019 daemon.info hostapd: wlan0: STA 50:76:af:dd:a4:dc IEEE 802.11: authenticated
Wed Aug 7 01:51:11 2019 daemon.info hostapd: wlan0: STA 50:76:af:dd:a4:dc IEEE 802.11: associated (aid 1)
Wed Aug 7 01:51:11 2019 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 50:76:af:dd:a4:dc
Wed Aug 7 01:51:11 2019 daemon.info hostapd: wlan0: STA 50:76:af:dd:a4:dc RADIUS: starting accounting session B729CDFF2432AE67
Wed Aug 7 01:51:11 2019 daemon.info hostapd: wlan0: STA 50:76:af:dd:a4:dc WPA: pairwise key handshake completed (RSN)
Wed Aug 7 01:51:11 2019 daemon.info dnsmasq-dhcp[2443]: DHCPREQUEST(br-lan) 192.168.8.248 50:76:af:dd:a4:dc
Wed Aug 7 01:51:11 2019 daemon.info dnsmasq-dhcp[2443]: DHCPACK(br-lan) 192.168.8.248 50:76:af:dd:a4:dc DESKTOP-CKI1BG2
Wed Aug 7 01:51:12 2019 daemon.warn odhcpd[1871]: DHCPV6 CONFIRM IA_NA from 0001000123d159ba9828a636769f on br-lan: not on-link fdc9:8869:17c8:10::d55/128
Wed Aug 7 01:51:12 2019 daemon.warn odhcpd[1871]: DHCPV6 SOLICIT IA_NA from 0001000123d159ba9828a636769f on br-lan: ok fdc9:8869:17c8:10::d55/128
Wed Aug 7 01:51:13 2019 daemon.info dnsmasq[2443]: read /etc/hosts - 4 addresses
Wed Aug 7 01:51:13 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/odhcpd - 0 addresses
Wed Aug 7 01:51:13 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Wed Aug 7 01:51:13 2019 daemon.info dnsmasq-dhcp[2443]: read /etc/ethers - 0 addresses
Wed Aug 7 01:51:14 2019 daemon.notice netifd: wwan (25296): udhcpc: sending discover
Wed Aug 7 01:51:14 2019 daemon.warn odhcpd[1871]: DHCPV6 REQUEST IA_NA from 0001000123d159ba9828a636769f on br-lan: ok fdc9:8869:17c8:10::d55/128
Wed Aug 7 01:51:14 2019 daemon.info dnsmasq[2443]: read /etc/hosts - 4 addresses
Wed Aug 7 01:51:14 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/odhcpd - 1 addresses
Wed Aug 7 01:51:14 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Wed Aug 7 01:51:14 2019 daemon.info dnsmasq-dhcp[2443]: read /etc/ethers - 0 addresses
Wed Aug 7 01:51:15 2019 daemon.notice netifd: wwan (25296): udhcpc: sending select for 192.168.2.36
Wed Aug 7 01:51:15 2019 daemon.notice netifd: wwan (25296): udhcpc: lease of 192.168.2.36 obtained, lease time 259200
Wed Aug 7 01:51:15 2019 daemon.notice netifd: Interface 'wwan' is now up
Wed Aug 7 01:51:15 2019 daemon.info dnsmasq[2443]: reading /tmp/resolv.conf.auto
Wed Aug 7 01:51:15 2019 daemon.info dnsmasq[2443]: using local addresses only for domain test
Wed Aug 7 01:51:15 2019 daemon.info dnsmasq[2443]: using local addresses only for domain onion
Wed Aug 7 01:51:15 2019 daemon.info dnsmasq[2443]: using local addresses only for domain localhost
Wed Aug 7 01:51:15 2019 daemon.info dnsmasq[2443]: using local addresses only for domain invalid
Wed Aug 7 01:51:15 2019 daemon.info dnsmasq[2443]: using local addresses only for domain bind
Wed Aug 7 01:51:15 2019 daemon.info dnsmasq[2443]: using local addresses only for domain lan
Wed Aug 7 01:51:15 2019 daemon.info dnsmasq[2443]: using nameserver 192.168.2.1#53
Wed Aug 7 01:51:15 2019 daemon.info dnsmasq[2443]: using nameserver 207.164.234.193#53
Wed Aug 7 01:51:18 2019 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Wed Aug 7 01:51:19 2019 kern.info kernel: [26076.257900] IPv6: ADDRCONF(NETDEV_UP): tmp.radio1: link is not ready
Wed Aug 7 03:42:19 2019 daemon.err gl_monitor[3154]: Failed to connect to the switch. Use the "list" command to see which switches are available.
Wed Aug 7 04:07:53 2019 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED 50:76:af:dd:a4:dc
Wed Aug 7 09:39:10 2019 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Wed Aug 7 12:06:03 2019 daemon.info hostapd: wlan0: STA d4:e6:b7:2c:11:d7 IEEE 802.11: authenticated
Wed Aug 7 12:06:03 2019 daemon.info hostapd: wlan0: STA d4:e6:b7:2c:11:d7 IEEE 802.11: associated (aid 1)
Wed Aug 7 12:06:03 2019 daemon.notice hostapd: wlan0: AP-STA-CONNECTED d4:e6:b7:2c:11:d7
Wed Aug 7 12:06:03 2019 daemon.info hostapd: wlan0: STA d4:e6:b7:2c:11:d7 RADIUS: starting accounting session BD0ED486975C895C
Wed Aug 7 12:06:03 2019 daemon.info hostapd: wlan0: STA d4:e6:b7:2c:11:d7 WPA: pairwise key handshake completed (RSN)
Wed Aug 7 12:06:06 2019 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED d4:e6:b7:2c:11:d7
Wed Aug 7 12:06:06 2019 daemon.info hostapd: wlan0: STA d4:e6:b7:2c:11:d7 IEEE 802.11: authenticated
Wed Aug 7 12:06:06 2019 daemon.info hostapd: wlan0: STA d4:e6:b7:2c:11:d7 IEEE 802.11: associated (aid 1)
Wed Aug 7 12:06:06 2019 daemon.notice hostapd: wlan0: AP-STA-CONNECTED d4:e6:b7:2c:11:d7
Wed Aug 7 12:06:06 2019 daemon.info hostapd: wlan0: STA d4:e6:b7:2c:11:d7 RADIUS: starting accounting session 414D3D87A8F01F13
Wed Aug 7 12:06:06 2019 daemon.info hostapd: wlan0: STA d4:e6:b7:2c:11:d7 WPA: pairwise key handshake completed (RSN)
Wed Aug 7 12:06:06 2019 daemon.info dnsmasq-dhcp[2443]: DHCPDISCOVER(br-lan) d4:e6:b7:2c:11:d7
Wed Aug 7 12:06:06 2019 daemon.info dnsmasq-dhcp[2443]: DHCPOFFER(br-lan) 192.168.8.225 d4:e6:b7:2c:11:d7
Wed Aug 7 12:06:06 2019 daemon.info dnsmasq-dhcp[2443]: DHCPREQUEST(br-lan) 192.168.8.225 d4:e6:b7:2c:11:d7
Wed Aug 7 12:06:06 2019 daemon.info dnsmasq-dhcp[2443]: DHCPACK(br-lan) 192.168.8.225 d4:e6:b7:2c:11:d7 Galaxy-A8-2018
Wed Aug 7 13:58:55 2019 daemon.info hostapd: wlan0: STA 50:76:af:dd:a4:dc IEEE 802.11: authenticated
Wed Aug 7 13:58:55 2019 daemon.info hostapd: wlan0: STA 50:76:af:dd:a4:dc IEEE 802.11: associated (aid 2)
Wed Aug 7 13:58:55 2019 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 50:76:af:dd:a4:dc
Wed Aug 7 13:58:55 2019 daemon.info hostapd: wlan0: STA 50:76:af:dd:a4:dc RADIUS: starting accounting session 8C1E5389E77DB7C0
Wed Aug 7 13:58:55 2019 daemon.info hostapd: wlan0: STA 50:76:af:dd:a4:dc WPA: pairwise key handshake completed (RSN)
Wed Aug 7 13:58:57 2019 daemon.warn odhcpd[1871]: DHCPV6 SOLICIT IA_NA from 0001000123d159ba9828a636769f on br-lan: ok fdc9:8869:17c8:10::313/128
Wed Aug 7 13:58:58 2019 daemon.warn odhcpd[1871]: DHCPV6 REQUEST IA_NA from 0001000123d159ba9828a636769f on br-lan: ok fdc9:8869:17c8:10::313/128
Wed Aug 7 13:59:00 2019 daemon.info dnsmasq-dhcp[2443]: DHCPDISCOVER(br-lan) 192.168.8.248 50:76:af:dd:a4:dc
Wed Aug 7 13:59:00 2019 daemon.info dnsmasq-dhcp[2443]: DHCPOFFER(br-lan) 192.168.8.248 50:76:af:dd:a4:dc
Wed Aug 7 13:59:00 2019 daemon.info dnsmasq[2443]: read /etc/hosts - 4 addresses
Wed Aug 7 13:59:00 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/odhcpd - 1 addresses
Wed Aug 7 13:59:00 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Wed Aug 7 13:59:00 2019 daemon.info dnsmasq-dhcp[2443]: read /etc/ethers - 0 addresses
Wed Aug 7 13:59:00 2019 daemon.info dnsmasq-dhcp[2443]: DHCPREQUEST(br-lan) 192.168.8.248 50:76:af:dd:a4:dc
Wed Aug 7 13:59:00 2019 daemon.info dnsmasq-dhcp[2443]: DHCPACK(br-lan) 192.168.8.248 50:76:af:dd:a4:dc DESKTOP-CKI1BG2
Wed Aug 7 13:59:01 2019 daemon.warn odhcpd[1871]: DHCPV6 CONFIRM IA_NA from 0001000123d159ba9828a636769f on br-lan: not on-link fdc9:8869:17c8:10::313/128
Wed Aug 7 13:59:01 2019 daemon.warn odhcpd[1871]: DHCPV6 SOLICIT IA_NA from 0001000123d159ba9828a636769f on br-lan: ok fdc9:8869:17c8:10::313/128
Wed Aug 7 13:59:01 2019 daemon.info dnsmasq[2443]: read /etc/hosts - 4 addresses
Wed Aug 7 13:59:01 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/odhcpd - 0 addresses
Wed Aug 7 13:59:01 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Wed Aug 7 13:59:01 2019 daemon.info dnsmasq-dhcp[2443]: read /etc/ethers - 0 addresses
Wed Aug 7 13:59:02 2019 daemon.warn odhcpd[1871]: DHCPV6 REQUEST IA_NA from 0001000123d159ba9828a636769f on br-lan: ok fdc9:8869:17c8:10::313/128
Wed Aug 7 13:59:02 2019 daemon.info dnsmasq[2443]: read /etc/hosts - 4 addresses
Wed Aug 7 13:59:02 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/odhcpd - 1 addresses
Wed Aug 7 13:59:02 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Wed Aug 7 13:59:02 2019 daemon.info dnsmasq-dhcp[2443]: read /etc/ethers - 0 addresses
Wed Aug 7 13:59:09 2019 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Wed Aug 7 14:04:19 2019 daemon.info hostapd: wlan0: STA 50:76:af:dd:a4:dc IEEE 802.11: authenticated
Wed Aug 7 14:04:19 2019 daemon.info hostapd: wlan0: STA 50:76:af:dd:a4:dc IEEE 802.11: associated (aid 2)
Wed Aug 7 14:04:19 2019 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 50:76:af:dd:a4:dc
Wed Aug 7 14:04:19 2019 daemon.info hostapd: wlan0: STA 50:76:af:dd:a4:dc RADIUS: starting accounting session 8C1E5389E77DB7C0
Wed Aug 7 14:04:19 2019 daemon.info hostapd: wlan0: STA 50:76:af:dd:a4:dc WPA: pairwise key handshake completed (RSN)
Wed Aug 7 14:04:19 2019 daemon.info dnsmasq-dhcp[2443]: DHCPREQUEST(br-lan) 192.168.8.248 50:76:af:dd:a4:dc
Wed Aug 7 14:04:19 2019 daemon.info dnsmasq-dhcp[2443]: DHCPACK(br-lan) 192.168.8.248 50:76:af:dd:a4:dc DESKTOP-CKI1BG2
Wed Aug 7 14:04:19 2019 daemon.warn odhcpd[1871]: DHCPV6 SOLICIT IA_NA from 0001000123d159ba9828a636769f on br-lan: ok fdc9:8869:17c8:10::313/128
Wed Aug 7 14:04:19 2019 daemon.info dnsmasq[2443]: read /etc/hosts - 4 addresses
Wed Aug 7 14:04:19 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/odhcpd - 0 addresses
Wed Aug 7 14:04:19 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Wed Aug 7 14:04:19 2019 daemon.info dnsmasq-dhcp[2443]: read /etc/ethers - 0 addresses
Wed Aug 7 14:04:20 2019 daemon.warn odhcpd[1871]: DHCPV6 REQUEST IA_NA from 0001000123d159ba9828a636769f on br-lan: ok fdc9:8869:17c8:10::313/128
Wed Aug 7 14:04:20 2019 daemon.info dnsmasq[2443]: read /etc/hosts - 4 addresses
Wed Aug 7 14:04:20 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/odhcpd - 1 addresses
Wed Aug 7 14:04:20 2019 daemon.info dnsmasq[2443]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Wed Aug 7 14:04:20 2019 daemon.info dnsmasq-dhcp[2443]: read /etc/ethers - 0 addresses
Also, I can still see the signal for 2G on my device. Seemingly, only the 5G signal cuts out every few minutes. It is plugged into a USB with the supplied cable.
This is very frustrating, as I am trying to work and am being interrupted every few minutes.
No it is not a power issue.
The signal is strong enough for a laptop to remain connected, so why cant your hardware?
I find it hilarious that I give a good amazon review, then suddenly the thing starts working like crap.
Im ready to throw this in the trash.
I use my slate in repeater mode as well and have the same issue. But i know what is the cause on my side: i login on a hotspot that only allows 10 clients or something. If someone else connects, i get kicked i guess. Since the the client side is not connected, the router side (same radio) drops as well.
I got used to it, perhaps your issue is a bit the same (crowded hotspot you repeat)?
Just forget it… I changed my feedback on amazon to 2 stars and just threw the slate in the trash.
It doesnt even work anymore at all, and im not going through this headache any more.
I had the same kind of trouble…Just solved making all in Luci…wireless…scan…join…here I put a name like wifi1 (or what you want) and then in advanced interface name, I put another name BUT NEVER “wlan-sta” that is the name automatically when you do this in WebUI. And never disconnects me again.
Thx
But the only thing is that you cannot see it in the WebUI first page connections even if you are connected in WISP mode…only that.
I’m trying this as of now, since this topic interests me as well. I notice that this router is offline in goodcloud as well since I didn’t configure as “wlan-sta”. Can you verify this on your side? Or you don’t use this?
Sorry I don’t use goodcloud.
But my AR750S never disconnects in WISP mode since I join WIFI networks in Client mode only with Luci and no “wlan-sta” named interface.
Same issue here. Using the stock power supply and having disconnects every 5-10 min if in repeater mode. It looks like it is rebooting because it goes through booting every time. Tried 3 different power supplies (yes, I have 3 Slates). When I disabled the 2.4Ghz (that is the Wifi spot I am connecting to) and let only the 5Ghz on then the issue is gone. I am using the latest 3.0.25
Okay seems to work, goodcloud came back after a reboot.However i do have to restart the radio frequently. Everything is up and connected, yet internet is not coming through…
I have the same issue. Frequent random disconnects when repeating 2.4G and 5G networks, no problems when hard-wired on 3.0.25. I will try the Luci workaround and report back, but this behavior really reduces my trust in this device.
I have a AR750S in Wisp/Client mode 2,4 Ghz channel to a router that is 20m outside home (15mbps connection) and my devices are connected to this one or to another AR750S (in WDS 5Ghz mode to the Wisp router) and depending in which zone of the house the devices connect to router #1 or #2. Not problems so far, my connection never fails even when downloading heavy files and 4 or 5 devices connected at the same time (most of them at the 2,4Ghz.) But I made connection with Luci and never put “wlan-sta” as name of interface. Bye
