is there such an app on the web interface or smartphone interface to test the connection speed?
There’s plenty around, just Google “speedtest”
Please read my question before you answer.
The speedtest app needs to be on the router itself.
For now, i have to ssh into x3000 and run a speedtest-cli written in python. This is not user friendly.
Search first on forum before u I ask. Speedtest builtin on the router is not a good idea can worn off the flash storage.
OpenSpeedTest is a HTML-only speedtest ‘app’. I just save the files to /www/ost on my X3000 and visit it with http://192.168.0.1/ost/index.html from a device connected to my LAN.
But, the more typical way to measure LAN speeds is to use iperf3.
Please read this answer before you reply again
Please read this other answer before you reply
I run this on a couple of Asus routers. Not sure if it can be done with openwrt with a USB drive, but it is just nginx with static files.
Like the Linksys speed test app?
