Glinet X3000 gateway randomly went down
I noticed today that yesterday something happened and the x3000 Gateway IP went down. It was no longer handing out a public IP to my firewall.
I have the x3000 setup in passthrough mode.
I don't ahev exact logs for some reason on the UI from when the firewall detected it as down but I do have these errors.
I can post the entire log file if needed.
I'm running 0409release3
Thu Jul 11 14:52:08 2024 kern.err kernel: [   41.125394] WiFi@C03L1,AndesSendCmdMsg() 754: Could not send in band command due to diablefRTMP_ADAPTER_MCU_SEND_IN_BAND_CMD
Thu Jul 11 14:52:08 2024 kern.warn kernel: [   41.136598] WiFi@C03L2,AndesSendCmdMsg() 765: Command type = ed, Extension command type = 48
Thu Jul 11 14:52:08 2024 kern.err kernel: [   41.145035] WiFi@C03L1,AndesSendCmdMsg() 754: Could not send in band command due to diablefRTMP_ADAPTER_MCU_SEND_IN_BAND_CMD
Thu Jul 11 14:52:08 2024 kern.warn kernel: [   41.156241] WiFi@C03L2,AndesSendCmdMsg() 765: Command type = ed, Extension command type = 48
Thu Jul 11 14:52:08 2024 kern.info kernel: [   41.232769] wdma_dma_ctrl(): WDMA_GLO_CFG=50404e70, txrx = 0
Thu Jul 11 14:52:08 2024 kern.info kernel: [   41.242027] wdma_dma_ctrl(): WDMA_GLO_CFG=40404e70, txrx = 0
Thu Jul 11 14:52:08 2024 kern.info kernel: [   41.256250] warp_tx_ring_init_hw(): configure ring 0 setting
Thu Jul 11 14:52:08 2024 kern.info kernel: [   41.261928] warp_tx_ring_init_hw(): wed:0000000099d0b870 wifi:00000000d46a00d3: 24420=520e8000,24424=2048,24428=0
Thu Jul 11 14:52:08 2024 kern.info kernel: [   41.272187] warp_tx_ring_init_hw(): configure ring 1 setting
Thu Jul 11 14:52:08 2024 kern.info kernel: [   41.277843] warp_tx_ring_init_hw(): wed:0000000099d0b870 wifi:00000000d46a00d3: 24430=52008000,24434=2048,24438=0
Thu Jul 11 14:52:08 2024 kern.info kernel: [   41.288220] set_rrocfg,0
Thu Jul 11 14:52:08 2024 kern.info kernel: [   41.313635] wdma_dma_ctrl(): WDMA_GLO_CFG=40404e74, txrx = 3
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.319299] using E1 ROM patch
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.322360] using E1 RAM
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.324891] current sync CR = 0x1
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.328209] 	Built date: 20220901174831a
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.332139] 	Platform: ALPS
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.334930] 	HW/SW version: 0x8a108a10
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.338681] 	Patch version: 0xffffffff
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.346431] current sync CR = 0x1
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.349751] 	Chip ID: 0x14
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.352447] 	Eco version: 0x00
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.355501] 	Region number: 0x0b
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.358729] 	Format version: 0x02
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.362039] 	Format flag: 0x01
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.365083] 	Ram version: ____000000
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.368657] 	Built date: 20220901174855
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.372497] 	Common crc: 0x62c52fee
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.375983] 	Release info: header tag = 0, total length = 64
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.381637] 	tag 1, padding length = 1, tag length = 59
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.386855] 	payload: t-neptune-main-mt7915-1953-MT7981_MP2111_IMP-20220901174750
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.415677] 	Chip ID: 0x00
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.418399] 	Eco version: 0x00
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.421455] 	Region number: 0x03
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.424671] 	Format version: 0x02
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.427980] 	Format flag: 0x01
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.431030] 	Ram version: DEV_000000
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.434618] 	Built date: 20220901175135
Thu Jul 11 14:52:08 2024 daemon.notice netifd: modem_0001 (10188): sh: 1: unknown operand
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.438475] 	Common crc: 0xdc1c7789
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.441986] 	Release info: header tag = 0, total length = 0
Thu Jul 11 14:52:08 2024 daemon.notice netifd: modem_0001 (10188): OK
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.526410] current sync CR = 0x7
Thu Jul 11 14:52:08 2024 kern.debug kernel: [   41.529838] efuse_probe: efuse = deaddead
Thu Jul 11 14:52:08 2024 daemon.notice netifd: modem_0001 (10188): ERROR
Thu Jul 11 14:52:08 2024 kern.err kernel: [   41.554190] WiFi@C02L1,is_cal_free_ic() 831: e[32m[a-die version:1]e[m
Thu Jul 11 14:52:08 2024 daemon.notice netifd: modem_0001 (10188): Failed to parse message data
Thu Jul 11 14:52:08 2024 daemon.notice netifd: modem_0001 (10188): cat: can't open '/tmp/run/dual_sim/modem_0001/current_sim': No such file or directory
Thu Jul 11 14:52:09 2024 daemon.notice netifd: modem_0001 (10188):
Thu Jul 11 14:52:09 2024 daemon.notice netifd: modem_0001 (10188): OK
Thu Jul 11 14:52:09 2024 daemon.err usbmuxd[11045]: [14:52:09.102][3] usbmuxd v1.1.1 starting up
Thu Jul 11 14:52:09 2024 daemon.err usbmuxd[11045]: [14:52:09.102][3] Using libusb 1.0.24
Thu Jul 11 14:52:09 2024 daemon.err usbmuxd[11045]: [14:52:09.103][3] Initialization complete
Thu Jul 11 14:52:09 2024 daemon.err usbmuxd[11045]: [14:52:09.104][3] Enabled exit on SIGUSR1 if no devices are attached. Start a new instance with "--exit" to trigger.
Thu Jul 11 14:52:10 2024 daemon.notice netifd: modem_0001 (10188):
Thu Jul 11 14:52:10 2024 daemon.notice netifd: modem_0001 (10188): OK
Thu Jul 11 14:52:10 2024 kern.err kernel: [   43.829639] WiFi@C17L1,RTMPReadTxPwrPerRate() 450: (450): Don't Support this now!
Thu Jul 11 14:52:10 2024 kern.err kernel: [   43.837158] WiFi@C01L1,AntCfgInit() 3118: Not support for HIF_MT yet!
Thu Jul 11 14:52:10 2024 kern.debug kernel: [   43.861110] ch_switch_monitor_state_machine_init:: enter
Thu Jul 11 14:52:10 2024 kern.debug kernel: [   43.866442] ch_switch_monitor_cfg_reset:: enter
Thu Jul 11 14:52:10 2024 kern.debug kernel: [   43.871004] ch_switch_monitor_cfg_reset:: enter
Thu Jul 11 14:52:10 2024 kern.err kernel: [   43.875939] WiFi@C17L1,tx_pwr_comp_init() 641: NotSupportYet!
Thu Jul 11 14:52:10 2024 kern.err kernel: [   43.881756] WiFi@C12L1,SCS_init() 880: INIT SCSEnable [0]= 1
Thu Jul 11 14:52:10 2024 kern.err kernel: [   43.887426] WiFi@C12L1,SCS_init() 887: INIT SCSEnable [1]= 0
Thu Jul 11 14:52:10 2024 kern.err kernel: [   43.893201] WiFi@C03L1,MtCmdSetMacTxRx() 10246: (ret = 0)
Thu Jul 11 14:52:10 2024 kern.err kernel: [   43.898708] WiFi@C03L1,MtCmdSetMacTxRx() 10246: (ret = 0)
Thu Jul 11 14:52:10 2024 kern.err kernel: [   43.904215] WiFi@C14L1,IPMacTable_init() 348: IPMacTable already inited!
Thu Jul 11 14:52:10 2024 kern.info kernel: [   43.931153] wdma_dma_ctrl(): WDMA_GLO_CFG=50804e75, txrx = 3
Thu Jul 11 14:52:10 2024 kern.err kernel: [   43.936963] WiFi@C03L1,MtCmdSetMacTxRx() 10246: (ret = 0)
Thu Jul 11 14:52:10 2024 kern.err kernel: [   43.942609] WiFi@C03L1,MtCmdSetMacTxRx() 10246: (ret = 0)
Thu Jul 11 14:52:10 2024 kern.err kernel: [   43.948043] WiFi@C00L1,mt_wifi_init() 653: <==== ZERO LOSS ::Disbaling FW Log =======>
Thu Jul 11 14:52:10 2024 kern.err kernel: [   43.956053] WiFi@C03L1,MtCmdFwLog2Host() 3419: N9(WM) (ret = 0)
Thu Jul 11 14:52:10 2024 kern.err kernel: [   43.962077] WiFi@C00L1,set_ack_timeout_mode_byband() 13357: CTS/ACK Timeout Range should between [0xFFFF:0]!!
Thu Jul 11 14:52:10 2024 kern.err kernel: [   43.971986] WiFi@C00L1,set_datcfg_ack_cts_timeout() 13445: DAT config band(0) cck_timeout Fail!
Thu Jul 11 14:52:10 2024 kern.err kernel: [   43.980680] WiFi@C00L1,set_ack_timeout_mode_byband() 13357: CTS/ACK Timeout Range should between [0xFFFF:0]!!
Thu Jul 11 14:52:10 2024 kern.err kernel: [   43.990586] WiFi@C00L1,set_datcfg_ack_cts_timeout() 13456: DAT config band(0) ofdm_timeout Fail!
Thu Jul 11 14:52:10 2024 kern.err kernel: [   43.999364] WiFi@C00L1,set_ack_timeout_mode_byband() 13357: CTS/ACK Timeout Range should between [0xFFFF:0]!!
Thu Jul 11 14:52:10 2024 kern.err kernel: [   44.009275] WiFi@C00L1,set_datcfg_ack_cts_timeout() 13467: DAT config band(0) ofdma_timeout Fail!
Thu Jul 11 14:52:10 2024 kern.err kernel: [   44.018142] WiFi@C00L1,set_ack_timeout_mode_byband() 13357: CTS/ACK Timeout Range should between [0xFFFF:0]!!
Thu Jul 11 14:52:10 2024 kern.err kernel: [   44.028059] WiFi@C00L1,set_datcfg_ack_cts_timeout() 13445: DAT config band(1) cck_timeout Fail!
Thu Jul 11 14:52:10 2024 kern.err kernel: [   44.036751] WiFi@C00L1,set_ack_timeout_mode_byband() 13357: CTS/ACK Timeout Range should between [0xFFFF:0]!!
Thu Jul 11 14:52:10 2024 kern.err kernel: [   44.046657] WiFi@C00L1,set_datcfg_ack_cts_timeout() 13456: DAT config band(1) ofdm_timeout Fail!
Thu Jul 11 14:52:10 2024 kern.err kernel: [   44.055436] WiFi@C00L1,set_ack_timeout_mode_byband() 13357: CTS/ACK Timeout Range should between [0xFFFF:0]!!
Thu Jul 11 14:52:10 2024 kern.err kernel: [   44.065340] WiFi@C00L1,set_datcfg_ack_cts_timeout() 13467: DAT config band(1) ofdma_timeout Fail!
Thu Jul 11 14:52:10 2024 kern.warn kernel: [   44.076962] WiFi@C00L2,dump_ht_cap() 29: Caller: dump_ht_cap+0x10/0x20 [mt_wifi]
Thu Jul 11 14:52:10 2024 kern.warn kernel: [   44.085690] WiFi@C00L2,dump_ht_cap() 29: Caller: dump_ht_cap+0x10/0x20 [mt_wifi]
Thu Jul 11 14:52:11 2024 user.warn : skip line without '=' Default
Thu Jul 11 14:52:11 2024 kern.debug kernel: [   44.315508] :(op = 1)
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.317988] 7981@C00L1,FastPathCheckMIC() 1010: (ret = 0)(op:1)
Thu Jul 11 14:52:11 2024 kern.warn kernel: [   44.324040] 7981@C00L2,red_tail_drop_init() 83: red_tail_drop_init: available token:8192, whnat_en:1
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.333269] 7981@C00L1,MtCmdCr4RedSet() 914: MtCmdCr4RedSet: (ret = 0)
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.339874] 7981@C00L1,SendRedCmd() 1049: SendRedCmd:(ret = 1)
Thu Jul 11 14:52:11 2024 kern.warn kernel: [   44.345848] 7981@C01L2,RTMP_COM_IoctlHandle() 1488:  -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_UP
Thu Jul 11 14:52:11 2024 kern.notice kernel: [   44.353887] WiFi@C01L3,wifi_sys_open() 856: wdev idx = 0
Thu Jul 11 14:52:11 2024 kern.notice kernel: [   44.359490] 7981@C18L3,BuildChannelList() 484:
Thu Jul 11 14:52:11 2024 kern.notice kernel: [   44.364089] 7981@C00L3,BuildChannelList() 514: BandIdx = 0, PhyMode = 78, ChListNum = 11:
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.372290] 7981@C14L1,vht80_channel_group() 1571: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.378660] 7981@C14L1,vht160_channel_group() 1640: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.385136] 7981@C14L1,vht80_channel_group() 1571: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.391504] 7981@C14L1,vht160_channel_group() 1640: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.397959] 7981@C14L1,vht80_channel_group() 1571: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.404332] 7981@C14L1,vht160_channel_group() 1640: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.410798] 7981@C14L1,vht80_channel_group() 1571: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.417164] 7981@C14L1,vht160_channel_group() 1640: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.423630] 7981@C14L1,vht80_channel_group() 1571: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.430006] 7981@C14L1,vht160_channel_group() 1640: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.436471] 7981@C14L1,vht80_channel_group() 1571: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.442843] 7981@C14L1,vht160_channel_group() 1640: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.449303] 7981@C14L1,vht80_channel_group() 1571: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.455684] 7981@C14L1,vht160_channel_group() 1640: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.462152] 7981@C14L1,vht80_channel_group() 1571: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.468518] 7981@C14L1,vht160_channel_group() 1640: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.474992] 7981@C14L1,vht80_channel_group() 1571: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.481371] 7981@C14L1,vht160_channel_group() 1640: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.487837] 7981@C14L1,vht80_channel_group() 1571: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.494215] 7981@C14L1,vht160_channel_group() 1640: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.500686] 7981@C14L1,vht80_channel_group() 1571: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.507060] 7981@C14L1,vht160_channel_group() 1640: invalid ch_band 0
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.513512] 7981@C23L1,DfsBuildChannelList() 3663: [RDM]: wdev is not 5G.
Thu Jul 11 14:52:11 2024 kern.notice kernel: [   44.520343] 7981@C23L3,RadarStateCheck() 244: Zero Wait State: 0
Thu Jul 11 14:52:11 2024 kern.notice kernel: [   44.526372] 7981@C23L3,operate_loader_phy() 394: oper_cfg: prim_ch(6), ht_bw(1), extcha(1), vht_bw(0), cen_ch_2(0), PhyMode=78!
Thu Jul 11 14:52:11 2024 kern.notice kernel: [   44.537868] 7981@C23L3,operate_loader_phy() 408: oper_dev after adjust: bw(1), prim_ch(6), cen_ch_1(8), cen_ch_2(0),ext_cha(1)!
Thu Jul 11 14:52:11 2024 kern.notice kernel: [   44.549355] 7981@C23L3,operate_loader_phy() 428: oper_radio after decision: bw(1), prim_ch(6), cen_ch_1(8), cen_ch_2(0)!
Thu Jul 11 14:52:11 2024 kern.notice kernel: [   44.560348] 7981@C03L3,MtCmdChannelSwitch() 2538: ctrl_chl=6, ctrl_ch2=0, cent_ch=8 DBDCIdx=0, ChBand=0, BW=1, TXStream=2, RXStream=2, scan(0)
Thu Jul 11 14:52:11 2024 kern.notice kernel: [   44.691140] 7981@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=6, ctrl_ch2=0, cent_ch=8, RxPath=3, BandIdx=0, ChBand=0, BW=1,TXStream=2, RXStream=3, scan(0)
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.704885] 7981@C12L1,EDCCAInit() 21006: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
Thu Jul 11 14:52:11 2024 kern.warn kernel: [   44.716221] WiFi@C00L2,dump_ht_cap() 29: Caller: wlan_operate_init+0xbc/0x160 [mt_wifi]
Thu Jul 11 14:52:11 2024 kern.debug kernel: [   44.724277] wdev_attr_update(): wdevId0 = 94:83:c4:a2:ff:1b
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.730005] WiFi@C12L1,wifi_sys_open() 907: wifi_sys_open():band0 group_idx[0]=0, bw_grp=16 omac=0
Thu Jul 11 14:52:11 2024 kern.notice kernel: [   44.739237] 7981@C08L3,hw_ctrl_flow_v2_open() 13: wdev_idx=0
Thu Jul 11 14:52:11 2024 kern.warn kernel: [   44.746586] 7981@C02L2,AsicRadioOnOffCtrl() 2340: DbdcIdx=0 RadioOn
Thu Jul 11 14:52:11 2024 kern.warn kernel: [   44.759850] 7981@C00L2,ApAutoChannelAtBootUp() 333: ----------------->
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.767496] 7981@C03L1,MtCmdSetMacTxRx() 10246: (ret = 0)
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.773563] 7981@C03L1,MtCmdSetMacTxRx() 10246: (ret = 0)
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.779103] 7981@C00L1,ApAutoChannelAtBootUp() 497: not A band
Thu Jul 11 14:52:11 2024 kern.err kernel: [   44.784970] 7981@C08L1,ap_run_at_boot() 623: e[41m ACS is disable !!e[m
Thu Jul 11 14:52:11 2024 kern.warn kernel: [   44.791835] 7981@C08L2,APStartUpForMbss() 983: ===>(caller:ap_inf_open+0x144/0x4e0 [mt_wifi]), mbss_idx:0, CfgMode:0
Thu Jul 11 14:52:11 2024 kern.warn kernel: [   44.80
Did the module not get the ip?
Are there any more logs?
@ywp
Yes here's the logs from openwrt and the logs from the Glinet x3000 UI
glinet_log_export.tar (169.4 KB)
openwrt_issue.tar (68.6 KB)
Incorrect log
The ui page should have a separate log page that can be exported
The second tar won't open
Besides, can I have a picture to describe the problem?
Both files open for me. I was able to open them as is and with changing extension to . txt as I couldn't upload .txt
The Glinet log export file is from the export button on the Glinet UI logs page.
I was not able to screenshot because I couldn't even access the UI while this was happening. It was down. It was not handing out a gateway address to my firewall and unreachable by the default address to reach the UI.
How did the x3000 light come on when the problem occurred
How often does it happen
The Internet and cellular lights were green and on when this was happening.
This is the first time I have been running this for a few weeks now.
Can a reboot restore normal?
I think this random issue is related to the Passthrough mode, I had enabled mine, and experience similar behavior
Can I enter the ui by setting static ip address?
Have a simple network topology diagram?
Let me see if I can replicate that
thank you
Yes a reboot fixed whatever was happening but since I couldn't access the UI or ssh I had to literally unplug it and plug it back in to fix it.
Here is a simple diagram. Glinet is serving a static interface address for the UI however to access the UI Glinet needs to advertise routes to the opnsense firewall which it didn't do during this issue. Not only was it not providing an IP to OPNsense but it also didn't advertise routes making it inaccessible.
           |      Cable Modem    |       |    GL-iNet Router   |
                     |  OpnSense Firewall  |
                     |     Main Switch     |
           |    Switch 1      |   |    Switch 2      |
                (Connected Devices)   (Connected Devices)
Would you happen to have had any logs from that? Interesting it might be related to passthrough.
Computer set static ip can not access?
The static IP set on the Glinet interface for lan UI access is not accessible during this time because it's in passthrough mode and not advertising routes when this issue occurs. So my firewall can't route my requests to the Glinet UI when this happened.
Normally as it's doing right now it's advertising the lan address, and the wan IP it's handing to OPNsense and the gateway address.
Can you show me the current firewall rules?
Make a comparison
Which firewall? Glinet or opnsense?
Are you talking about routes on opnsense?
I never touched the firewall rules on Glinet.
On opnsense I have access to the interface address I set in Glinet.
The route is advertised via the gateway address. Essentially if there's no Gateway address provided to opnsense then I can't reach the Glinet UI.
Here are the routes where GATEWAY-IP is the gateway address. and 192.168.20.2 is the default address I configured for Glinet UI access on LAN
ipv4 Public-IP GATEWAY-IP
ipv4 192.168.20.2 GATEWAY-IP
These two logs in normal times
Is that a question? I never touched the timezone.
One is from Glinet UI and the other openwrt.
I mean get the current log
