in glinet 1300M the wifi signal is not emitting. please help me. if any one have idea
Did you try back to factory setting?
thanks for your response, yes bro i have done factory setting? mesh is formed but signal is not emitting.
Do you have only one router or multiple?
To reset the router, you need to press and hold the reset button for 10 seconds. Did you set up mesh again after that?
