I have been using the browser to access the KVM UI without issues, usually Google Chrome, but I just found out there is also a desktop app ”GLKVM app”. What are the differences?
One is a self-contained app? If I’m not mistaken, the app requires cloud connectivity.
The difference is only the experience.
I use the browser regularly from different systems (private PC, private laptop, travel laptop, work laptop) to access computers/laptops remote. It is fast, easy, and works without much setup. (Comet RM1, Comet X)
I use the App to connect from Mobile (Android (phone and tablet), iPhone) to relatives mobile phones to support. It is fast, less trouble with scaling on the small screen, easy access to the settings.
But this is my work flow, it would also work on a browser. Depending on how many Comet you are using the List could help instead of bookmarks in the browser.
The app can use ‘local access’ (manual entered host/IP), and do not depend on the Cloud..
Hi, thanks for your question!
The main difference is how you access and manage your KVM.
glkvm.local or the KVM's IP address. You can also use the GLKVM Cloud service through your browser for remote access.As far as actual KVM features go, they're pretty much identical. If you're already comfortable using Chrome, there's no need to switch—the app is mostly just there for a more convenient way to handle remote access and keep track of your devices.
You can find more information about the GLKVM App here: GLKVM App documentation
