GLKVM V1.5.1 V1.5.1 release1 does not allow pasting
Latest update to the GLKVM app does not allow host computer to paste onto the app.
I now need to manually type out the password for GLKVM or if I need to use the toolbox to paste to remote device. This really degrades the user experience.
Edit: It seems to be an issue with the CTRL key not being registered correctly?
We will fix this soon. please wait for a while.
Thanks for releasing the fix this quickly!
Hello, GLKVM V1.5.1 release2 also does not allow pasting on windows 11.
system_logs_20260901_064026.zip (239.6 KB)
Nor does it work on GLKVM.com
It does work on MacOS GLKVM V1.5.1 release1
Hi, could you please let us know which OS you're using on the controlled and the controller device? Also, please clarify how you're trying to paste.
I am on Windows 11 controlling a different Windows 11 device using a Comet (GL-RM1).
I have updated my GLKVM app to V1.6.0 release 1 and pasting seems to work again.
