GLKVM Virtual Media & Zoom
Please add option to disable Virtual Media so on host system there would be no devices like:
Linux File-Store Gadged USB device
Linux File-CD Gadget USB device
Also please consider adding zoom functionality to browser client
Thnx!
Stop sharing and these devices will not appear.
We will consider adding scaling to KVM. For now, if the screen is too small, you can try switching to 1920*1080 resolution.
Note that the EDID modification function is only supported in versions 1.1.1 or above.
Sharing is not enabled, I cannot even see any option to disable sharing
Btw - EDID is a GREAT option!
I have recorded the relevant requirements and will update our version plan after the holiday and share it with users.
I found solution at the other thread (disable sharing devices)
Apend to /etc/kvmd/override.yaml
kvmd:
        msd:
                type: disabled
But would be nice to have this option in GUI
UI will be added in future versions
