There seems to be an issue with wireless bridging on GL-SFT1200 when the SSID is hidden it does not connect even if entered manually.
Scenario is the following:
I have 2 GL-SFT1200's, one in router mode the other in extender mode.
If I hide the SSID on the router unit in router mode then the extender does not connect.
If I make the SSID visible again it will connect immediately. If I hide the SSID (set visibility=hidden) afterwards then the extender will remain connected until it is power cycled. After power cycle, the extender mode unit refuses to connect again.
Model GL-SFT1200
Firmware: 4.3.17
