GLX-3000 Port Fowarding
I am trying to set up remote access for an NVR that is connected to my GLX-3000, but can't seem to get the port forwarding correct.
I have included a screenshot showing what I believe is the IP address of the sim card I am using as well as the port forwarding rule I set up.
What am I doing wrong?
Thank you!
Port forwarding does not work while using cellular. That is by design of the cellular network - using CGNAT - not because of the router.
I am sorry.
The SIM IP 10.229.231.95 is using the CGNAT, not real public IP, the port forwarding and only available to access on the Internet when the router WAN is public IP.
Thank you both.
I have used cradlepoint and peplink routers for this purpose in the past with no issues and was hoping to try something different.
Can anything be modified on the GLX-3000 to make it perform like the cradle point?
I am not familiar with cradle point, but if you build a VPN, and the server is public available, you could do a port forward to the VPN server which routes in the VPN to the GL-X3000.
Not what I would prefer, but depending on the needs maybe a solution.
Can try to check if your router modem has the real public IP
