GLx3000 - 6 Antennas - How to use with external?
I’m wondering why the Spitz router has 6 antenna connectors. My Navilock roof antenna only provides 2x LTE and 2x Wi-Fi. Can I still use it with the Spitz?
From what I’ve seen online, the Spitz also supports GPS. Does it require a separate external GPS antenna, or is that module internally integrated?
In my setup, the router will be mounted under the bench seat, which doesn’t offer great LTE or GPS reception. I could leave the remaining two connectors (e.g., unused LTE or GPS ports) disconnected, but I’m unsure how much that would impact performance.
Any insights or best practices regarding antenna configuration with the Spitz would be appreciated.
2x2 wifi support, apparently your antenna doesn't support that.
Nur i found this:
4 x Cellular Antennas (SMA, 600M~6GHz)
2 x Wi-Fi Antennas (PR-SMA, 2.4G~2.5GHz, 5.15~5.84GHz
I guess
2x cellular sim 1
2x cellular sim 2
I would not think so, there is only 1 modem in the router. it could be 4 antenna for cellular - mine is in my RV and not readily available to see.
So I can’t use my Navilock antenna with two connectors for this router?
Do you have an antenna you would recommend? Preferably with a GPS module?
Parsec makes a couple that would work (Husky) and Peplink 42g are on my list, but I am using in an RV so ymmv with those. There are plenty out there - just need to google for the proper frequencies to get full support of 5g.
You Need a 4x4 Mimo Antenna
