Glx3000 not turning on
as the title sugests my gl x3000 5g router dose not turn on anymore. it hasnt been dropped or damaged in any way, just stopped working. any help would be appreciated.
Is the router rebooting all the time?
no, the router will just not start up. seems to not be getting power but i have tried the cable on different devices and it works.
Plug it in, does the light not turn on?
Can we try another cable for the x3000?
Is this the same cable you used to use? All of a sudden it’s not working out?
