I have activated Good Cloud.
This also appears as Online on the GoodCloud interface.
But I cannot access the device.
There are also no devices displayed that are in the router’s network.
What is the problem?
Did you enable the remote access?
try to manually add it into GoodCloud.
If I deactivate WireGuard, it works.
Why?
Try to enable GL Services to go through the VPN tunnel - it seems you were not reaching GoodCloud through an activated tunnel.
ok, it works. Thank you
