Tiny bugs in Goodcloud:
Label 5G Wireless:
Wrong number of devices and empty list:
Thanks, I will ask developer to fix it.
This bug has fixed. Thanks for your feedback.
Here’s another one.
When connected through WireGuard, it shows connected, but not the statistics.
Cheers.
LED control has not been added to 4.0, this button should not be shown on SlateX page.
Thank for you feedback, we will fix it soon.
What will it do once you have included?
The LED control Page will be added in version 4.1, user can control the LED light switch and set the timer switch on the Router Web.
Because some people think the lights are too bright, they need to turn off the lights before going to bed.
Then there will be buttons on GoodCloud to control the LED switch.
Ha. I had to look twice before I saw the (dim) light on the front.
Umm perhaps this function should be implement ASAP for the Beryl instead. People have been asking for since it was released.
