Goodcloud keeps showing router offline
My router keeps appearing offline is there anyway to fix this issue? I have manually deleted and added back same issue.
Could you please post the cloud log of your router?
What router do you use and which firmware?
I assume its been offline from the start now. I just checked the cloud log nothing there. I set this up 3 months ago and just had to use it yesterday.
Firmware: 4.4.60
Please try to disable Goodcloud and enable it again - check logs again then.
Is your router able to talk to the internet at all?
Do you use any other upstream router?
What DNS server do you use?
Router is working online presently which is why it confused me when I tried to connect to goodcloud outside my home.
Only the gli_net router in the house
DNS: AdGuard Home is enabled, the router must use the DNS server provided by AdGuard Home, you can’t customize DNS servers.
Do you see the DNS request to gl-cloud?
No a 1000 reconnects to mqtt. Should I disable adguard and try again?
Yup, try it for testing.
This is what the system log is saying:
Its saying time stamp invalid is that causing the issue?
Fixed the time issue and that seems to have fixed the issue will keep adguard off for the foreseeable future its not needed anyway. Thanks for your help
AGH works well with Goodcloud, I use it myself.
I found the solution every time that you delete or reset the setting of any GLinet router to communicate again to good cloud web app properly you need to enable HTTPS remote access and SSH remote access and allow ping from wan, by that it will properly function correctly
This sounds not right, no.
But you are required to re-bind the device in GoodCloud.
i set up the server but i am not getting a lot of speed , what can i do please?
Don't know what you mean. But pls post a separte thread descriping your issue in more details.
