Goodcloud login with Google account
Hi there,
created a Goodcloud account on the web using my Google account which worked fine.
However on the device (Beryl), there is no option to login to Goodcloud using the Google Account.
Now I can’t create a new Goodcloud account with the same email as it thinks I aleady have one!
How to fix?
M
If your account is used to log in to GoodCloud using Google for the first time, after you successfully log in, please go to the personal center and set a login password.
Then log in to the router GL GUI, you can log in and bind your router to your GoodCloud platform with your Google account + the password you just set.
Go to the Goodcloud web login page.
Select “Forgot password?” (or similar option).
Enter your Google email. wisely card
Goodcloud should send you a password-reset link to your Gmail.
Use that link to set a password for your account. This creates a password for logging in without Google.
