Hi!
This is from my Goodcloud portal
Can you tell me how/where the Flint2 is performing these tests to get these results?
Im on a 1Gbps synchronous broadband package and dont see these results when I perform a speedtest from my mobile on the wifi.
Hi!
From the router:
I did notice though, this dropped when I turned off Wireguard Client.
The router isnt set to use the VPN so why is the router using the VPN for anything other then the 2 MAC devices i've specified in the policy?
It is the latency from your router to reach the GoodCloud server. For reference only.
It is not latency of your access the Internet service.
ok thats good then ![]()
