There is a Notification option called "SIM Card Traffic Monitoring" and it allows notifications at a percentage of use - but I cannot find anywhere that you can set what the max data limit is. I have a SIM on a 500GB/Month deal that is via a 3rd party reseller so there is no way to monitor the use - I had hoped the router could at least warn if it was getting close but can't find a way to do it.
"Percentage" in Notification "SIM Card Traffic Monitoring" of GoodCloud is calculated based on thresholds on firmware GUI.
You can fill in the monthly traffic limit in the GL GUI:
OK - I am on a GL-X3000 with latest stable firmware 4.7.4 and I don't see half the options that those docs are showing - I can see the traffic used figures but there is no way to modify them - do you know what firmware version those came in on?
