why your Web Server’s IP is 192.168.1.25?
I think the Computer which run the Web Server is connect to the GL-MT300N-V2 (Node 1) , right?
The computer should get a IP like 192.168.10.x from the GL-MT300N-V2 (Node 1).
You should use the IP(192.168.10.x) of the computer.
Make sure the two router can ping each other, and try connect the web server by router GL-MT300N-V2 in Site B, If everything goes well, web server should can be connected by router GL-MT300N-V2 in Site A.
Yes, from my PC on site A, I can ping the GL-MT300N-V2 on site B and I can also access the Control Panel of the GL-MT300N-V2 on site B by typing his LAN IP (192.168.10.1) in the address bar .
Therefore the connection should work.
The problem is that I cannot reach webserver2 (192.168.10.25) which is connected to the LAN port of the GL-MT300N-V2 on site B.
So I can’t reach clients on the LAN side of the GL-MT300N-V2 on Site B. But I can reach devices which are connected with the WAN side of the GL-MT300N-V2 on Site B, e.g. the webserver1 on Site B with the IP 192.168.1.25 is reachable from my PC on Site A.
Here is an overview of how the devices are connected.
I have a question, when Webserve2 connect to the LAN port of GL-MT300N-V2 on site B, find a computer/phone to connect to the GL-MT300N-V2 on site B, can the computer/phone access the Webserve2 ?
You try to ping 192.168.1.10, 192.168.10.1 and 192.168.10.25 with your PC (192.168.2.5) in Site A , what is the result? It is better have some screenshot to analyse the bug.
Pinging 192.168.2.1 with 32 bytes of data:
Reply from 192.168.2.1: bytes=32 time=3ms TTL=64
Reply from 192.168.2.1: bytes=32 time=5ms TTL=64
Reply from 192.168.2.1: bytes=32 time=41ms TTL=64
Ping statistics for 192.168.2.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 3ms, Maximum = 41ms, Average = 13ms
C:\Users\samfa>ping 192.168.0.1
Pinging 192.168.0.1 with 32 bytes of data:
Reply from 192.168.0.1: bytes=32 time=4ms TTL=63
Reply from 192.168.0.1: bytes=32 time=3ms TTL=63
Reply from 192.168.0.1: bytes=32 time<1ms TTL=63
Reply from 192.168.0.1: bytes=32 time=2ms TTL=63
Ping statistics for 192.168.0.1:
Minimum = 0ms, Maximum = 4ms, Average = 2ms
C:\Users\samfa>ping 192.168.10.1
Pinging 192.168.10.1 with 32 bytes of data:
Reply from 192.168.10.1: bytes=32 time=315ms TTL=63
Reply from 192.168.10.1: bytes=32 time=551ms TTL=63
Reply from 192.168.10.1: bytes=32 time=472ms TTL=63
Reply from 192.168.10.1: bytes=32 time=84ms TTL=63
Ping statistics for 192.168.10.1:
Minimum = 84ms, Maximum = 551ms, Average = 355ms
C:\Users\samfa>ping 192.168.1.1
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 time=230ms TTL=62
Reply from 192.168.1.1: bytes=32 time=113ms TTL=62
Reply from 192.168.1.1: bytes=32 time=61ms TTL=62
Reply from 192.168.1.1: bytes=32 time=98ms TTL=62
Ping statistics for 192.168.1.1:
Minimum = 61ms, Maximum = 230ms, Average = 125ms
C:\Users\samfa>ping 192.168.1.25
Pinging 192.168.1.25 with 32 bytes of data:
Reply from 192.168.1.25: bytes=32 time=297ms TTL=62
Reply from 192.168.1.25: bytes=32 time=52ms TTL=62
Reply from 192.168.1.25: bytes=32 time=58ms TTL=62
Reply from 192.168.1.25: bytes=32 time=54ms TTL=62
Ping statistics for 192.168.1.25:
Minimum = 52ms, Maximum = 297ms, Average = 115ms
C:\Users\samfa>ping 192.168.10.25
Pinging 192.168.10.25 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.10.25:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Today, I use two GL-MT300N-V2 with 3.102 to test the Site to Site, it worked.
I want to add a device to your GoodCloud, then we try to test it.
I will send a forum message to you.
