GoodCloud can only be used as long as the main node is not also operated as a VPN client to a provider. This should be explicitly stated in the GoodCloud instructions.
Or GoddCloud should act as “main node”, then all other nodes could be VPN clients (via WireGuard) on VPN servers as well as provide internal connections to each other.
You cannot use one node for everything.
That’s what I wrote above - a clear hint at the GoodCloud documentation would be helpful and not only here something about “complex”…
Especially since it concerns ONLY the main node!
Yes you are right. Developers will follow up this.
