Goodcloud Timeout even when Device is online
OpenWrt 21.02-SNAPSHOT r15812+1082-46b6ee7ffc
Fri Jan 10 20:42:47 2025 daemon.info gl-cloud[13236]: (gl-cloud:1096) lua-eco version: 3.7.0
Fri Jan 10 20:42:47 2025 daemon.info gl-cloud[13236]: (gl-cloud:441) Ubus services init done.
Fri Jan 10 20:42:47 2025 daemon.info gl-cloud[13236]: (gl-cloud:700) fetch ca from: https://gslb-eu.goodcloud.xyz/getCaCert/ca.crt
Fri Jan 10 20:42:47 2025 daemon.info gl-cloud[13236]: (gl-cloud:745) fetch server from: https://gslb-eu.goodcloud.xyz/getTlsBucket
Fri Jan 10 20:42:48 2025 daemon.info gl-cloud[13236]: (gl-cloud:832) connect mqtt broker: 100.28.9.71 28883
Fri Jan 10 20:42:48 2025 daemon.info gl-cloud[13236]: (gl-cloud:1004) conack: 0 connection accepted
hi, when i LogIn i get:
"Device Response Timeout" on Flint2
i have also a Slate and Beryl which are both accessable with the WebGui or Manage
GoodCloud is green activated with 2FA and i see all devices
i removed the Flint several times and it will only apply by adding manually, not by auto
info: auto-discover is not working
// thx for any help
devoce
i do not need to open any further ports - because on the Slate and Berly it is working
without opening additional ports (sitting behind a Router)
i applied all switches in the same way like on the slate and did not change firewall
as far i can see in LuCi
should i try to open another GoodCloudAccount ? i already reseted the Firmware with the same error
when i connect with WG-Client (Slate with Mobile) to the WGServer on the Flint2 (ISP), i can access the Adminpanel - but WebGui with GoodCloud will not open
when i access the adminspanel of the Flint2 (ISP) with the GL-DDNS xxxxx.glddns.com i can also access the adminpanel successfully over the slate (mobile)
devoce
only from the GoodCloudAccount -> WeBGui i get this ^^
GoodCloud on Flint is bound
Try unbid goodcloud then bind again.
after 2FA it says applied after but staying yellow
it doesent change - not wit Username in combination with emailcode or other way around
notice: i can Login with Username/emailadress and use OTP or email-code
tried all combinations with rebooting inbetween
so i can delete the Flint from goodcloud and unbind in Adminpanel
-> then 2FA will add the Flint in GoodCloudAccount as Device, but Cloud
will not come up Green like you see in the picture
now it will not bind again:
Wed Jan 15 23:48:21 2025 daemon.info gl-cloud[10129]: (gl-cloud:1096) lua-eco version: 3.7.0
Wed Jan 15 23:48:21 2025 daemon.info gl-cloud[10129]: (gl-cloud:441) Ubus services init done.
Wed Jan 15 23:48:21 2025 daemon.info gl-cloud[10129]: (gl-cloud:700) fetch ca from: https://gslb-eu.goodcloud.xyz/getCaCert/ca.crt
Wed Jan 15 23:48:22 2025 daemon.info gl-cloud[10129]: (gl-cloud:745) fetch server from: https://gslb-eu.goodcloud.xyz/getTlsBucket
Wed Jan 15 23:48:22 2025 daemon.info gl-cloud[10129]: (gl-cloud:832) connect mqtt broker: 100.28.9.71 28883
Wed Jan 15 23:48:23 2025 daemon.info gl-cloud[10129]: (gl-cloud:1004) conack: 0 connection accepted
@bruce something his/her problem with certificate Goodcloud?
Your WAN does have public IP ?
No, its a static IP deligated by the Main-Router (where i did open the Ports for WireGuard and VPN) So the Flint gets from the MainRouter a Static-IP and i put this IP here:
The WireGuard-Devices use a selfhost-domain (mainrouter forwarding) in the WG-Configurations to forward the changing IP4 of the mainrouter. This runs pretty stable.
Is this ruining Goodcloud ? because i changed the DHCP to static ?
as i said above, the goodcloud webgui adding the router, but its stays offline in the goodcloud account and in the webgui it will not log in - the cloud staying yellow
/etc/init.d/gl-cloud status
and after that
/etc/init.d/gl-cloud restart
and then
logread | grep gl-cloud
Solution -> thx Admon again
You are welcome :seal:
yep this did it also for me :smiling_face_with_three_hearts:
