I have a three part question:
Part 1:
Is it possible currently to have a router in Goodcloud to be shared and accessed by multiple users? I've setup a router for a friend and I tried "sharing the device" by shared devices. Upon entering his email address I get an error being told there is no such user.
Is this possible to share his router with him?
Part 2:
By default GoodCloud uses port 80 to access routers despite no ports being open. Is this less or more secure if I leave it by the default setting rather then opening up Port 443 to the entire web on the router itself? Or is port 80 only open specifically for GoodCloud and to the entire web on the device itself? I just want to make sure I'm leaving no stone unturned.
Part 3:
I have an old Android phone that doesn't allow for WPA3 support. It currently is connected to the guest network. I'd like to make an exception if possible for this device via Firewall rules to be able to access resources on the main network. For example a resource that this device would need to access is an NVR security system. On previous configurations with WPA2 security the device was able to access this network resource without an issue. Now it is not able to access this resource due to the new standards of the WPA3 protocol.
Thanks,
