GoodPas on smartphone and PC
I enabled GoodPas on my Flint 4 and easily set it up on the Mudi 7 as well.
I saw on the Play Store that there’s a GoodPas app; I downloaded it, but when I tried to set it up with the code, I got an error, and I think it’s not compatible.
Do you know if the app will be updated to make it compatible with the Flint 4’s GoodPas?
Also, are there plans to develop an app for Linux Fedora and Windows that’s compatible with the Flint 4’s GoodPas?
Regards
Enrico
Hi Enrico,
The Flint 4 or other routers' current firmware does not yet support connections from the GoodPAS app. We will add the support in a future router firmware update.
The Windows app is available from our GoodPAS download page.
A Linux version is still under evaluation.
If I may speak up for Linux (Fedora), more and more people are switching to some Linux distribution (especially in Europe, but not only there), so it might be very useful to release this version as well in the near future.
And I can't wait for compatibility with Flint 4 as well.
Thank you!
Dear Enrico,
I was able to us GoodPAS with Flint 3 (at home) and Flint 2 (Traveling) and it worked fine.
I was able to access all my home websites.
Can you advise if GoodPAS will come to My Old Flint 1 (GL-AX1800) or Opal (GL-SFT1200)?
Hi @neswin1,
Thanks for sharing your experience!
GoodPAS support is expected to come to the Flint (GL-AX1800), but we cannot yet confirm whether it will be available for the Opal (GL-SFT1200).
