I have a server running in my home network (Roon) that communicates with clients via UDP broadcast/multicast (not sure which).
To do this I use a tool called UDP Proxy 2020 (GitHub - synfinatic/udp-proxy-2020: A crappy UDP router for the year 2020 and beyond)
When I use Wireguard on my MacBook it works fine across the VPN and the Mac client connects to the server.
When I use the Wireguard client in my GT-MT3000 the Mac connecting to the router can’t connect to the server via the VPN.
What is happening? Is there blocking of the UDP broadcast/multicast happening between 192.168.4.0/24 (Wireguard) and 192.168.8.0/24 (GL-MT3000) networks?
I tried to change a firewall rule in LuCI that seems to drop anything going from Wireguard to elsewhere, but the rule doesn’t save or is overridden elsewhere.
I don’t know enough to debug or proceed so if anyone else has an idea I’d really appreciate the help.
