Guest network isolation is not working
Hi everyone!
I have an MT-3000 with two 2.4GHz Wi-Fi networks, one internal and one guest. The first network is 192.168.2.0/24 and the guest network is 192.168.3.0/24. What I need is to allow internet access on both subnets, but I don’t want the guest devices to be able to reach the devices inside the main network. Right now, I can ping the devices in both directions, and this is not what I want. I have already checked the "AP Isolation" inside the guest network settings and the “isolate client” option inside LuCI (luci/admin/network/wireless). If you need any more info, please ask as I might have forgotten something.
Thanks!!
You should not need to do anything and it should work for you.
If you can ping each other subnet pls just post screenshots.
Hi, thank you for your response. As you can see from the screen below, from the guest network (3.0/24), I can ping the IPs on the private subnet (2.0/24). 192.168.2.1 is now working, which is correct because it is the IP of the router. I can also ping a guest device from my private subnet, but in this case, I don’t know if this is correct or not. I can also ping all the devices through the VPN from my guest subnet (I don’t have a screenshot of this case right now, sorry). Any ideas to solve this problem?
I verifed on my MT3000 (firmware v4.7).
I turned on guest network, change to 192.168.3.1/24 subnet.
Change private network to 192.168.2.1/24 subnet.
My router works correctly. Here is what it should be
  1. On guest network (3.1/24) you cannot ping 2.1, 2.2 etc.
  2. On private network (2.1/24) you ccannot ping 3.1/24 network
  3. On guest network (3.1/24) you cannot ping each other (3.x)
This is achieved using the default config, nothing need to do in luci.
Kindly let me know what else you configured so that I can check.
This is exactly what i was expecting. Probably there are some bugs in the code. I have this router running no stop from a lot of time, and i have always updated the router keeping the config. maybe something stopped working. I will proceed resetting the router, and i will let you know.
Ok, i reset the firmware from the web gui, and now the guest network is working properly!
Thank for your help!
