Hey guys, I install my router and connected to the VPN client. I installed the Guest network and got a question, Can I separate the Guest network from the Client VPN connection and go to the regular connection ?
on other words, I want my home wireless network connect to the VPN, but the Guest network does not at the same time.
This Flint. How to bypass VPN For all Guest devices? - #10 by alzhao should do the trick.
Hello @admon this is to isolate guests from seeing each other. However, I'm looking to skipping vpn for guests (while the router is connected to vpn) and connecting to the regular connection.
The directly linked post is about disabling VPN for guest network.
I tried what in the link already, but that's for isolating the Guest devices from each other.
However, I have seen some posts saying do the VPN policy and I checked that and I don't have that option on my router. I'm using the "ATX1800" is it different device and not supporting what we are looking for ?
All GL devices support VPN policy. You will find them on the VPN dashboard. (At least if your device isn't a chinese one)
You are right. I found that yesterday before I see your response lol. I clicked on everything except that option I wish if they have it on better setup for thin one. I think we are good here. Thank you guys for your help!.
