Guest networks
Are the guest networks completely isolated from the main network? I mean they have the same BSSID as the main network. How difficult is it to reach the router or other devices through the guest network?
They do not hve same BSSID. No wifi in the same area could use the same BSSID.
Guest networks are completely separately from the private network.
To hack this, you need to hack the router first and change the firewall.
What? But there is two main networks (2.4 and 5 GHz) with different BSSID. And two additional guest networks (2.4 and 5 GHz) with same BSSID as main networks.
Can you please send screenshot what do you mean?
BSSIDs should be different for all Wi-Fi networks within your area.
SSID can be same, no problem.
I did not meant that. The guest network 2,4 GHz have same BSSID as main network 2,4 GHz. It seems like you have never checked this out. Same with 5GHz.
