I would like to know where are the technical data (e.g. the terminal used to connect, the date, time and duration of communications, MAC address) of the guest network on the GL-AR750 and if it is possible to save them.
Thank you for your answer.
The guest network logs are not there. Only those of the WIFI network that is recognized by the router and only at the time of this connection. There is no history of previous connections either.
