I’d like Guest Wifi Users to be able to access a web server that resides on the Local Network that has a static IP assigned by the GL.Inet device (Not the Wan).
The Device is in Router Mode.
Is this possible? I tried adding a firewall rule but it doesn’t seem to help.
Internal IP MyStaticIP (ie, 192.168.1.2)
External Ports: 80
Internal Ports:80
Protocol: TCP/UDP
Status:Enabled
Guest Wifi User is trying the URL http://192.168.1.2 with no success.
