Guest WiFi - are devices isolated from each otther?
The GL iNet documentation isn’t clear if devices connected to the Guest wifi connection are isolated from each other. It says they cannot access the admin web console but doesn’t expand.
Are they isolated from each other?
If not, how can they be?
Thanks!
Hello ! You can config this in Luci
http://192.168.8.1/cgi-bin/luci/admin/network/wireless (if your network is 192.168.8.1)
Then Select your Guest Wifi networks there and go to Advanced Settings then down Interface Coinfiguration
Select Isolate Clients
I hope that what is you wanted.
+1 I had this EXACT issue, and this was the EXACT fix, thank you so much!
