I have Wireguard client on my ar300m and want the guest wifi to connect to the internet directly (bypassing Wireguard). Is that possible?
It is the default behavior.
Guest WiFi does not go through vpn.
That’s great. Thank you very much.
Update: I tested the guest WiFi with WireGuard client connected and unfortunately guest WiFi traffic goes go through VPN.
Really. I will check with dev team.
