Tested FW version: 4.1.0-166
- Reset to factory defaults
- Never touch the Wi-Fi from the GL.iNet Wireless page, only use LuCI for Wi-Fi
- SSH to the router
- Type
opkg update && opkg remove wpad-openssl && opkg install wpad-openssl --force-overwrite - Configure mesh like you would from OpenWrt Wiki in LuCI.
My current mesh configuration to be used as an example with 802.11r and 802.11kv using usteer:
Slate AX is the mesh main
Command: opkg install usteer ; service usteer enable ; server usteer start
Content: /etc/config/wireless
config wifi-device 'radio0'
option type 'mac80211'
option path 'platform/soc/c000000.wifi'
option band '5g'
option htmode 'HE80'
option htmod 'HE80'
option country 'US'
option cell_density '0'
option channel '161'
option channels '36,40,44,48,149,153,157,161,165'
option rts '500'
config wifi-iface 'default_radio0'
option device 'radio0'
option network 'lan'
option mode 'ap'
option encryption 'psk2+ccmp'
option ssid 'Example'
option dtim_period '3'
option key 'password'
option bss_transition '1'
option wnm_sleep_mode '1'
option time_advertisement '2'
option time_zone 'GMT0'
option ieee80211k '1'
option rrm_neighbor_report '1'
option rrm_beacon_report '1'
option ieee80211r '1'
option ft_psk_generate_local '1'
option ft_over_ds '0'
config wifi-device 'radio1'
option path 'platform/soc/c000000.wifi+1'
option band '2g'
option noscan '1'
option channel '11'
option htmode 'HE40'
option rts '500'
config wifi-iface 'default_radio1'
option device 'radio1'
option mode 'ap'
option ssid 'Example-2.4G'
option skip_inactivity_poll '1'
option disassoc_low_ack '0'
config wifi-iface 'wifinet2'
option mode 'mesh'
option encryption 'sae'
option mesh_id 'Example-Mesh'
option mesh_fwding '1'
option mesh_rssi_threshold '0'
Archer C7 v2 is the mesh peer
Command: opkg remove wpad-basic-wolfssl ; opkg install wpad-wolfssl
option path 'pci0000:00/0000:00:00.0'
option band '5g'
option htmode 'VHT80'
option rts '500'
option beacon_int '100'
option country 'US'
option path 'platform/ahb/18100000.wmac'
option band '2g'
option noscan '1'
option htmode 'HT40'
option disabled '0'
option rts '500'
option channel '3'
option country 'US'
config wifi-iface 'wifinet1'
option mode 'ap'
option mode 'ap'
config wifi-iface 'wifinet3'
option mode 'mesh'
Extras:
usteercan also help certain devices to steer from 2.4Ghz to 5Ghz with equal SSID (requires configuration - not recommended) - Compared to WDS (fake bridging/L3) and “Extender” (proxy/relay ARP): with roaming the transition speed with mesh/802.11s is around 60ms, 130ms without, making 802.11r actually useful with mesh or wired back haul/dumb-AP, whereas it’s somewhat useless with repeaters and WDS as they take ~350ms on average when roaming. It is noticeable with VoWiFi calls silent periods and video calls reducing quality & taking a minute before restoring full bit rate.
- Use
FT-over-Airfor roaming. - IPv6 is more stable with 802.11s than WDS/RA-relay from my tests.
- 802.11k/v is only useful with Windows, Pixel + few Android phones, and modern Linux distros.You can skip
usteerand k/v configuration. -
usteeris needed for 802.11k/v , to check peering infoubus call usteer get_clients
