Hardware question
If I will run router without antenna, won't it become destroyed or damaged?
I need to make test. After some time I will attach it again
Router X750
It won't but the signal will be very bad for sure.
I know. I need to perform some tests. I mean change antennas to another ones. When I attach and then change to another one there will be time when router runs without antenna. Won't it damage it?
No, there is no reason for damage.
As I know some transmitters can be damaged because of antenna removal. So I decided to ask. Thx!
Let @bruce as official GL staff confirm it.
Remove the antennas would not result in damage the hardware function.
