Upgraded my X750v2 from v3.217 (sms working fine) to v4.0 (openwrt-x750-4.0-release70307-1222-1703233128.bin) and there is no way (that I can find) to create an SMS message!
The screen is just blank.
I think that the smstools3 server is working as I can create a USSD cmd file in /etc/spool/sms/outgoing/1-1.2 and it gets sent AND I get a reply. But I’m not going to ssh into the router just to send an sms!!
My suspicion that I hope you experts can conform is, that luci-app-smstools3 is missing? And what’s more it is not in the GL-iNet opkg repos.
Hello, the repaired beta firmware has been placed on the download website. You can go to the website to download it and test to see if there are any remaining issues. GL.iNet download center (gl-inet.com)
Hmmm… Different but…
Are you pre-processing (and reporting Invalid Number)? Because 669 is a perfectly valid USSD code for me - If it was sent, it will responds with my data balance.
Yes. Or more accurately I’m sending a USSD (Unstructured Supplementary Service Data) “Quick Code” to request a data balance. This is a snippet from my LTE service provider:
… and this is sample of a message:
To: 669
To_TOA: international
Modem: GMS99
Sent: 24-03-24 10:04:22
Sending_time: 1
IMSI: xxxxxxxxxxxxxxx
IMEI: yyyyyyyyyyyyyyy
info uk22rwg
… and if placed in the folder /etc/spool/sms/outgoing/1-1.2/ will get sent. So the underlying services are fine. It is just that the User Interface is not working.
Okay,
I see that the beta has now moved from: openwrt-x750-4.3.13-0325-1711360933.bin to openwrt-x750-4.3.13-0326-1711441894.bin.
I’m busy for the next 3 or 4 days but I will test and let you know.
Okay, for your info.
I am able to send USSD messages with the beta firmware openwrt-x750-4.3.13-0326-1711441894.bin
As an aside - Can I have the CRON logs turned on again?
Regards, M.
